Glances a top command alternative
Discussion in 'Centmin Mod Insights' started by eva2000, Jan 1, 2017.
    60,147
    12,594
    12:45 AM
    should work fine did on my centos 7 system with ccache weird
    for CentOS 7, use
    yum -y install python2-pip
    to get pip there first
    60,147
    12,594
    12:45 AM
    working psutil update with ccache in place
    did a force reinstall and filter egrep on ccache and installed keywords as verbose output -v is alot
    pip install --upgrade psutil --force-reinstall -v | egrep 'ccache|installed'
          Successfully uninstalled psutil-5.4.3
        ccache gcc -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=543 -DPSUTIL_LINUX=1 -I/usr/include/python2.7 -c psutil/_psutil_common.c -o build/temp.linux-x86_64-2.7/psutil/_psutil_common.o
        ccache gcc -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=543 -DPSUTIL_LINUX=1 -I/usr/include/python2.7 -c psutil/_psutil_posix.c -o build/temp.linux-x86_64-2.7/psutil/_psutil_posix.o
        ccache gcc -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=543 -DPSUTIL_LINUX=1 -I/usr/include/python2.7 -c psutil/_psutil_linux.c -o build/temp.linux-x86_64-2.7/psutil/_psutil_linux.o
        writing list of installed files to '/tmp/pip-CNGGgO-record/install-record.txt'
    Successfully installed psutil-5.4.3
  3. pamamolf
    4,128
    4:45 PM
    Doesn't work :
    error: command 'ccache' failed with exit status 1
    60,147
    12,594
    12:45 AM
    Also can try uninstall psutil and reinstalling. Might need to run uninstall twice and upgrade pip first too
    pip install --upgrade pip
    pip uninstall psutil
    pip install psutil
    if that doesn't work disable ccache for just this SSH session
    export CC='gcc'
    pip install psutil
    with export CC variable to remove ccache would result in
    pip install --upgrade psutil --force-reinstall -v | egrep 'ccache|gcc|installed'
        gcc -pthread -shared -Wl,-z,relro build/temp.linux-x86_64-2.7/psutil/_psutil_common.o build/temp.linux-x86_64-2.7/psutil/_psutil_posix.o build/temp.linux-x86_64-2.7/psutil/_psutil_linux.o -L/usr/lib64 -lpython2.7 -o build/lib.linux-x86_64-2.7/psutil/_psutil_linux.so
        gcc -pthread -shared -Wl,-z,relro build/temp.linux-x86_64-2.7/psutil/_psutil_common.o build/temp.linux-x86_64-2.7/psutil/_psutil_posix.o -L/usr/lib64 -lpython2.7 -o build/lib.linux-x86_64-2.7/psutil/_psutil_posix.so
        writing list of installed files to '/tmp/pip-UPqUxn-record/install-record.txt'
  5. pamamolf
    4,128
    4:45 PM
    doesn't work and the issue exist on all Centos 7 older installations....
    60,147
    12,594
    12:45 AM
    @pamamolf updated previous command to show how to temp disable ccache but
    @Andy @pamamolf just updated 123.09beta01 code to auto update pip, psutil and glances on centmin.sh runs ;) So just update 123.09beta01 code via centmin.sh menu option 23 submenu option 2, exit centmin.sh and reenter centmin.sh or you can run cmupdate command that was recently added and re-run centmin.sh menu option and then exit.
    Then verify versions
    pip show psutil pip glances
    Version: 5.4.3
    Summary: Cross-platform lib for process and system monitoring in Python.
    Home-page: https://github.com/giampaolo/psutil
    Author: Giampaolo Rodola
    Author-email: g.rodola@gmail.com
    License: BSD
    Requires:
    Version: 9.0.1
    Summary: The PyPA recommended tool for installing Python packages.
    Home-page: https://pip.pypa.io/
    Author: The pip developers
    Author-email: python-virtualenv@groups.google.com
    License: MIT
    Requires:
    Version: 2.11.1
    Summary: A cross-platform curses-based monitoring tool
    Home-page: https://github.com/nicolargo/glances
    Author: Nicolas Hennion
    Author-email: nicolas@nicolargo.com
    License: LGPLv3
    Requires: psutil
  7. pamamolf
    4,128
    4:45 PM
    It has issues with psutil installation as the manual way :(
  8. pamamolf
    4,128
    4:45 PM
    Ok i test this also:
    But nothing:
    fatal error: Python.h: No such file or directory
    and then:
    error: command 'gcc' failed with exit status 1
  9. Andy
    Andy Active Member
    546
    90
    9:45 AM
    couldn't install psutils
    Command "/usr/bin/python2 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-M19xbM/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-9q4LDx-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-M19xbM/psutil/
    60,147
    12,594
    12:45 AM
    ah strange python-devel package is missing
    yum -y install python-devel
    then try
  11. pamamolf
    4,128
    4:45 PM
    Ok i fix it :)
    Looks like you haven't properly installed the header files and static libraries for python dev.
    So i did:
    and now:
  12. pamamolf
    4,128
    4:45 PM
    That one also works with no issues:
    and now i am getting this when i run glances:
  13. Andy
    Andy Active Member
    546
    90
    9:45 AM
    Yup. Looks like that's it. Thanks all.
  14. pamamolf
    4,128
    4:45 PM
    It seems now my issue to be glances old version?
  15. pamamolf
    4,128
    4:45 PM
    Yup !!!!!
    Running this:
    All working great now !!!!!
    George you may need to check the installation of python-devel on the system and the upgrade routine also of Centminmod for glances that you just add a few minutes ago?
  16. pamamolf
    4,128
    4:45 PM
    I am also getting this warning when i start glances:
    Don't know if you know how to fix this also...
  17. Andy
    Andy Active Member
    546
    90
    9:45 AM
    My glances version is higher
    glances -V
    Glances v2.11.1 with psutil v5.4.3
  18. pamamolf
    4,128
    4:45 PM
    I got the new version also after running:
    60,147
    12,594
    12:45 AM
    FYI, should be all fixed in latest 123.09beta01 code updated less than 10 seconds ago :D
  20. pamamolf
    4,128
    4:45 PM
    Yes now it is auto fixing the issue :)
    Only that warning when it starts:
    No big deal but just to let you know :)
