PHP-FPM gethostbyaddr problem
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Oxide, Jan 14, 2018.
  1. Oxide
    Oxide Active Member
    515
    29
    9:54 AM
    I've noticed that gethostbyaddr seems to crash php-fpm and throw 502 errors. Max children problem occurs etc.. Anyone know any solution to this?
    I have an API, that requires gethostbyaddr and other dns lookups.. Maybe 50-100 r/s that seems to crash the server.
    39,244
    8,656
    9:54 AM
    • Server or VPS details ? XEN, KVM, OpenVZ, VMWare or dedicated server ? OS ? CentOS 6.9 or 7.4 ? 32bit or 64bit ?
    • Specific error messages in php-fpm and nginx logs ?
    Nginx 502 or 504 Bad Gateway Errors
    Bad gateway 502 /504 timeouts are usually related to Nginx timing out waiting on PHP-FPM to respond as PHP-FPM is overloaded or overwhelmed with requests, so may need to tune PHP-FPM values. It also maybe due to PHP-FPM in turn being queued and backed up waiting on MariaDB MySQL server to respond - so also need to look at MySQL.
    You'll need to tune your PHP-FPM settings with php-fpm main pool config file at /usr/local/etc/php-fpm.conf (overview of config files) and this is left up to end user to do but here's a thread for starters to enable php status page output outlined at
    Checking PHP-FPM etc logs
    You'll also need to check into your PHP-FPM, Nginx and MariaDB logs which you can find as outlined at How to troubleshoot Centmin Mod initial install issues
    Server logs include Nginx, PHP-FPM, MariaDB MySQL error logs as well as others. You can find your Centmin Mod install/menu logs at FAQ 7 and server logs at FAQ 19 at Centmin Mod FAQ (most up to date info in FAQ so always read that first). Spoiler tag below has info too but may not be up to date.
    Some of Centmin Mod's installed software will have their own access and error logs which maybe useful for diagnosing errors or give info, notes, or warning notices.
    Note: There's no support provided by me for diagnosing such errors which may occur for various reasons including misconfiguration of installed php/mysql scripts or applications.
    In SSH2 telnet you can use tail command to view the last X number of lines in the file.
    For example for viewing last 10 lines in the file for:
    For Nginx access and error logs:
      tail -10 /usr/local/nginx/logs/access.log
      tail -10 /usr/local/nginx/logs/error.log
    For other system error logs located at /var/log:
    list /var/log files in ascending time order so the most recently modified files are at the bottom
      ls -lhrt /var/log
    total 2.7M
    -rw------- 1 root  root    0 Aug 29 15:33 tallylog
    -rw------- 1 root  root    0 Aug 29 15:33 spooler
    drwx------ 3 root  root 4.0K Aug 29 15:35 samba
    drwxr-xr-x 2 root  root 4.0K Aug 29 15:35 mail
    -rw-r--r-- 1 root  500     0 Oct  8 18:13 dmesg.old
    -rw------- 1 root  500     0 Oct  8 18:13 boot.log
    -rw-r--r-- 1 root  500     0 Oct  8 18:14 dmesg
    drwx------ 2 root  root 4.0K Oct  8 18:14 httpd
    drwxr-xr-x 2 root  root 4.0K Oct  8 19:08 php-fpm
    -rw-rw---- 1 mysql root 2.3K Oct  9 12:38 mysqld.log
    -rw------- 1 root  root 9.2K Oct 26 10:48 yum.log
    -rw------- 1 root  utmp  94K Nov  7 22:59 btmp
    drwxr-xr-x 2 root  root 4.0K Nov  8 00:00 sa
    -rw------- 1 root  root 269K Nov  8 21:39 messages
    -rw------- 1 root  root 110K Nov  8 23:08 secure
    -rw-rw-r-- 1 root  utmp  43K Nov  8 23:08 wtmp
    -rw-r--r-- 1 root  root 144K Nov  8 23:08 lastlog
    -rw------- 1 root  root  69K Nov  8 23:08 lfd.log
    -rw------- 1 root  root 332K Nov  8 23:08 maillog
    -rw------- 1 root  500  1.6M Nov  8 23:10 cron
    For PHP-FPM error log:
      tail -10 /var/log/php-fpm/www-error.log
    and/or
      /var/log/php-fpm/www-php.error.log
    For MySQL / MariaDB error log:
      tail -10 /var/log/mysqld.log
    For CSF firewall LFD log:
      tail -10 /var/log/lfd.log
    For Mail log:
      tail -10 /var/log/maillog
    For Cron job logs:
      tail -10 /var/log/cron
    How to edit php.ini and php-fpm configuration files ?
    Centmin Mod install created command short cuts outlined here to allow you to quickly edit your /usr/local/lib/php.ini file and your /usr/local/etc/php-fpm.conf file. Full list of command shortcuts below:
    • Edit php.ini = phpedit ( /usr/local/lib/php.ini )
    • Edit my.cnf = mycnf ( /etc/my.cnf )
    • Edit php-fpm.conf = fpmconf ( /usr/local/etc/php-fpm.conf )
    • Edit nginx.conf = nginxconf ( /usr/local/nginx/conf/nginx.conf )
    • Edit (nginx) virtual.conf = vhostconf - only edits /usr/local/nginx/conf/conf.d/virtual.conf not the additional vhost domain.com.conf files added later
    • Edit (nginx) php.conf = phpinc ( /usr/local/nginx/conf/php.conf )
    • Edit (nginx) drop.conf = dropinc ( /usr/local/nginx/conf/drop.conf )
    • Edit (nginx) staticfiles.conf = statfilesinc ( /usr/local/nginx/conf/staticfiles.conf )
    • nginx stop/start/restart = ngxstop/ngxstart/ngxrestart
    • php-fpm stop/start/restart = fpmstop/fpmstart/fpmrestart
    • mysql stop/start/restart = mysqlstop/mysqlstart/mysqlrestart
    • nginx + php-fpm stop/start/restart = npstop/npstart/nprestart
    • memcached stop/start/restart =memcachedstop/memcachedstart/memcachedrestart
    • csf stop/start/restart = csfstop/csfstart/csfrestart
    Troubleshooting Tools
    However, there's many linux tools and scripts that can help you figure out what was causing the load issues and when.
    Notes:
  3. Oxide
    Oxide Active Member
    515
    29
    9:54 AM
    It appears on whatever server that I installed centminmod on. So there isn't much to add here.
    I honestly think your default response to every topic will not make others help anyone, they'll leave it to you.
    39,244
    8,656
    9:54 AM
    Yeah though hope is folks help each other out too. It's all about experience. Once you figure the issues out, then you'll have experience :)
