PHP 8.3.31 wont compile on CentOs 7
Discussion in 'Install & Upgrades or Pre-Install Questions' started by GASTAN, May 17, 2026.
  1. GASTAN
    GASTAN Member
    111
    12
    8:26 PM
    I am trying to upgrade PHP from 8.3.30 to 8.3.31 on CentOS 7 with CentminMod 132.
    I get this error:
    PHPMUVER = 8.3
    PHP_PGO = n
    make -j4
    /svr-setup/php-8.3.31/ext/openssl/xp_ssl.c: In function <E2><80><98>php_openssl_matches_san_list<E2><80><99>:
    /svr-setup/php-8.3.31/ext/openssl/xp_ssl.c:502:45: error: subscripted value is neither array nor pointer nor vector
    502 | ASN1_STRING_get0_data(san->d.iPAddress)[0],
    any idea what could be the problem ?
    59,718
    4:26 AM
    59,718
    4:26 AM
    Ok figured out the CentOS 7 specific OpenSSL 1.0.2 issue with newer PHP versions and updated with a patch fix in 132.00stable, 140.00beta01, 141.00beta01. Just need to run cmupdate before retrying centmin.sh menu option 5. Issue is on PHP 8.2.31, 8.3.31 and next PHP 8.4/8.5 releases.
    PHP 8.3.31 (and 8.2.31, plus all 8.2/8.3/8.4/8.5 branch HEADs) backported upstream commit 19255f4b78 which switched ext/openssl/xp_ssl.c's SAN IP address handling to OpenSSL 1.1.0+'s ASN1_STRING_get0_data() accessor - but CentOS 7 ships OpenSSL 1.0.2k which doesn't declare that function. So the compiler treats its return type as implicit int and chokes on int[0] subscripting.
    Centmin Mod fixes this on EL7 only with a new patch patches/php/php82-openssl102-xp_ssl-asn1.patch that inserts a 12-line static compat shim into xp_ssl.c (mirroring PHP's own openssl.c shim) returning M_ASN1_STRING_data(asn1), gated by #if PHP_OPENSSL_API_VERSION < 0x10100, applied via a content-detected EL7-only block in inc/php_patch.inc that auto-handles current and future affected PHP point releases and skips cleanly once upstream lands a real fix.
    Plain English: Newer PHP versions (8.3.31 and 8.2.31 and next PHP 8.4/8.5 releases) started using a modern OpenSSL helper function to read IP addresses out of SSL certificates — but CentOS 7's OpenSSL is too old to have that helper, so the compiler doesn't recognize the function, guesses wrong about what it returns, and gives up with a confusing error when PHP tries to grab the first byte of the address. Centmin Mod fixes this on CentOS 7 only by slipping in a tiny 12-line "translator" snippet at the top of the affected PHP file that teaches old OpenSSL how to do the new thing, and a smart detector in the upgrade script that automatically applies the fix when needed and quietly stays out of the way otherwise.
  4. GASTAN
    GASTAN Member
    111
    12
    8:26 PM
    Thx, it compiled now.
    But I still get php-fpm crashes ;(
    59,718
    4:26 AM
