FTP issues timeout
Discussion in 'Other Centmin Mod Installed software' started by joshuah, Apr 18, 2017.
  1. joshuah
    joshuah Member
    121
    14
    11:53 AM
    • Nginx Version Installed: 1.11.10
    • PHP Version Installed: i 7.0.18
    Command: PWD
    Response: 257 "/" is your current location
    Command: TYPE I
    Response: 200 TYPE is now 8-bit binary
    Command: PASV
    Response: 227 Entering Passive Mode (xxx,xx,xxx,xxx,xxx,40)
    Command: MLSD
    Error:        The data connection could not be established: ETIMEDOUT - Connection attempt timed out
    Error:        Connection timed out after 20 seconds of inactivity
    Error:        Failed to retrieve directory listing
    I've tried every auth option, disabling CSF, etc.
    Anything else I can try?
    Thanks.
    Edit: using latest filezilla on MAC.
    55,811
    12,273
    11:53 AM
    Do you have a local PC firewall in place ? Your local PC might need to whitelist passive ports and ensure Explicit TLS/SSL connections are set as outlined at Pure-FTPD Virtual FTP Users - CentminMod.com LEMP Nginx web stack for CentOS
    Also see FAQ items 40 & 41 for details and clues.
  3. joshuah
    joshuah Member
    121
    14
    11:53 AM
    Hi mate, i am using a macbook and have the firewall disabled. It is strange because it works fine for other hosts, just not this configuration for some reason.
    55,811
    12,273
    11:53 AM
    other hosts using centmin mod or other hosts using non-centmin mod setups ?
    DO NOT disable CSF Firewall as it setups up proper passive ftp support for pure-ftpd. If you disable CSF Firewall, pure-ftpd virtual ftp with passive ports will NOT work.
  5. joshuah
    joshuah Member
    121
    14
    11:53 AM
    Sorry, I meant I disabled the local macbook firewall.
    I meant, other hosts in general.
    55,811
    12,273
    11:53 AM
    That is usually firewall related though. Does your local PC go through a router/switch ? It might need whitelisting at that level.
  7. joshuah
    joshuah Member
    121
    14
    11:53 AM
    Dang. It was a firewall sitting infront of my VPS. I had to open port 30001 - 500011.
    55,811
    12,273
    11:53 AM
    ah ha.. web host vultr ?
  9. joshuah
    joshuah Member
    121
    14
    11:53 AM
    Yep.. CSF was configured right, but it was the firewall sitting infront, which is pretty neat (in a way) :)
    55,811
    12,273
    11:53 AM
    k updated ftp and Step 2 Getting Started Guide pages with a note for other firewalls :)
    55,811
    12,273
    11:53 AM
