FTP Connection Timed Out
Discussion in 'Other Centmin Mod Installed software' started by Lux, May 15, 2017.
  1. Lux
    Lux New Member
    Worldwide
    7:19 AM
    • CentOS Version: i.e. entOS 7 64bit
    • Nginx Version Installed: latest available til this date.
    • PHP Version Installed: 7.0.0
    • When was last time updated Centmin Mod code base ? : recent update
      LETSENCRYPT_DETECT='y'
      NGINX_IPV='y'
      PHP_VERSION='7.0.0'
      NGINX_PAGESPEED=y
    Here's my error:
    Status:    Connection established, waiting for welcome message...
    Response:    220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
    Response:    220-You are user number 2 of 1000 allowed.
    Response:    220-Local time is now 14:31. Server port: 21.
    Response:    220-This is a private system - No anonymous login
    Response:    220-IPv6 connections are also welcome on this server.
    Response:    220 You will be disconnected after 15 minutes of inactivity.
    Command:    AUTH TLS
    Error:    Connection timed out after 20 seconds of inactivity
    Error:    Could not connect to server
    An Arubacloud vps.
    I have ports opened:
    30001 to 50011
    I tried with the IP, still not working.
    [I also tried to use ftptest.net and it doesn't connect.] update: I've created a new user and ftptest.net is now showing success.
    I can access ssh/sftp though. Thank you.
    55,425
    12,257
    9:19 AM
    • Did you let the script generate a password for you or set your own ?
    • Did you make sure to enable explicit TLS/SSL mode and enable PASV passive mode like in 1st post here.
    • Which FTP client ? As not all FTP clients support FTP explicit TLS/SSL mode only clients listed at bottom of this post.
    • If you are having trouble with logging in using the generated pure-ftpd username and password, you can try changing the password for the pure-ftpd username with instructions outlined at Pure-FTPD Virtual FTP Users - CentminMod.com LEMP Nginx web stack for CentOS
    • Check if you're ISP IP address is being blocked by CSF Firewall. See FAQ items 40 & 41.
    You can read up on pure-ftpd virtual ftp user setup at Pure-FTPD Virtual FTP Users
    55,425
    12,257
    9:19 AM
    ah so the created pure-ftpd username didn't work
