Wordpress FTP connection on plugin update issue
Discussion in 'Blogs & CMS usage' started by Afaq, Apr 16, 2016.
  1. Afaq
    Afaq Member
    81
    11:37 AM
    I installed the WordPress using the automatic option. Now, I am trying to update some plugin and it is asking me to enter the FTP information. Even though I am entering the right credentials, it is not working. The dialog box disappears for a second and then comes back. Any idea how can I disable this extra piece of security?
    Thanks.
    55,163
    12,249
    4:37 PM
    Updating Wordpress plugin from WP admin plugin page ? it shouldn't need to prompt for FTP user details. How was the specifc WP plugin initially installed ? via WP admin plugin > add new plugin or via standard FTP user update as root user or as Pure-ftpd virtual user ? If used standard FTP user upload to initially install WP plugin, then follow Getting Started Guide step 2 and chown the right user and group permissions to nginx
    Easiest way is to ensure you install WP plugins via WP admin plugin > add new plugin so the installed files have correct user and group permissions.
    Also are you using any caching like WP Super Cache or KeyCDN Cache Enabler ? ensure you have configured them not to cache logged in users as well as outlined at Wordpress Nginx Auto Installer (WP Super Cache)
