Install Fresh install and ultimate problems
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Jaro13, Feb 12, 2016.
  1. Jaro13
    Jaro13 New Member
    12:55 AM
    Problem with install.
    I know its very basic problem but I'am not able to find solution.
    After Fresh install with github option on centos 6:
    #php -v command ( as root) - bash return - bash unknown command.
    same for
    nginx -V
    # which php
    /usr/bin/which: no php in (/usr/lib64/ccache:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
    Centos 6 config as follows
    #uname -a
    Linux serv1 2.6.32-573.18.1.el6.x86_64 #1 SMP Tue Feb 9 22:46:17 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
    Thanks for your help!
    Jaro
    55,380
    12,255
    8:55 AM
    You decided to play with Centmin Mod when it's dealing with nginx 1.9.11 compatibility issues with 3rd party modules. See Nginx 1.9.11 dynamic module compatibility | Centmin Mod Community Should be temporarily resolved now I have temp disabled the conflicting modules.
    So best to reload fresh CentOS 6.7 OS and try again a fresh install.
    If that doesn't work, you'll need to post on the forums with the following info
    • Server or VPS details ? XEN, KVM, OpenVZ, VMWare or dedicated server ? OS ? CentOS 6.7 or 7.1 ? 32bit or 64bit ?
    • What version of Centmin Mod ? .07 stable or .08 beta03 or .08 stable or .09 beta01 ?
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
