Fresh Beta01 Instal on CentOS7.x
Discussion in 'Install & Upgrades or Pre-Install Questions' started by cloud9, Dec 23, 2021.
  1. cloud9
    cloud9 Premium Member Premium Member
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    • CentOS Version: i.e. CentOS 6 32bit or 64bit / CentOS 7 64bit ?
    • Centmin Mod Version Installed: i.e. 123.08stable or 123.09beta01
    • Nginx Version Installed: i.e. 1.15.3
    • PHP Version Installed: i.e. 5.6.37, 7.0.31, 7.1.21, 7.2.9
    • MariaDB MySQL Version Installed: i.e. 10.0.x or 10.1.xx or 10.2.xx
    • When was last time updated Centmin Mod code base ? : i.e. run centmin.sh menu option 23 submenu option 2 or cmupdate command
      Post output in CODE tags.
  2. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    I have the mysql root pw from the install but its not working, I can reset this but just wondered why its not recognising it
    PHP8.1
    Version: 123.09beta01.b760
    Current Nginx Version: 1.21.4 (221221-171005-centos7-kvm-57b1995)
    55,158
    12,249
    3:59 AM
    Not working where? on command line like
    mysqladmin ver
    Could be auto generated password has a character in it that needs /root/.my.cnf to wrap the password in single quotes?
  4. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    Ok, reinstalled the VPS and still have the same issue
    Trying to creat a DB
    # mysqladmin -u root -pFDtCRfrczVvD3oxNboJUqwMIJxcF create ffa349
    mysqladmin: connect to server at 'localhost' failed
    error: 'Access denied for user 'root'@'localhost' (using password: YES)'
  5. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    I have tried the root pw for the server and also the mysql pw that Centmin generated on install - both give me the same error so cant create a db
  6. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    # mysqladmin ver
    55,158
    12,249
    3:59 AM
  8. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    55,158
    12,249
    3:59 AM
    Ah you sanitised the log but what was the old MariaDB MySQL root password set in the log next to the line
    MySQL root password: **************************
    Just curious if the auto generated password had a character MySQL didn't like.
    Yeah sounds like auto generated password had a character that MySQL maybe didn't like.
    55,158
    12,249
    3:59 AM
    FYI, I removed the log zip as some passwords still revealed. Probably best to do a fresh reinstall of OS and Centmin Mod.
    55,158
    12,249
    3:59 AM
    Checked the initial install log more and noticed a few MariaDB YUM repo error messages though MariaDB MySQL server itself was installed properly
    Not using downloaded mariadb/repomd.xml because it is older than what we have:
      Current   : Tue Nov  9 21:49:27 2021
      Downloaded: Tue Nov  9 21:42:47 2021
    http://mirror.zetup.net/repoforge/redhat/el7/en/x86_64/rpmforge/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    Trying other mirror.
    To address this issue please refer to the below wiki article
    https://wiki.centos.org/yum-errors
    If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
    But this one's weird, MariaDB 10.2 YUM packages attempted to install for MariaDB 10.3 repo?
     Package             Arch        Version                     Repository    Size
    Installing:
     MariaDB-shared      x86_64      10.2.41-1.el7.centos        mariadb      112 k
    Transaction Summary
    Install  1 Package
    Total download size: 112 k
    Installed size: 343 k
    Downloading packages:
    http://yum.mariadb.org/10.3/centos7-amd64/rpms/MariaDB-shared-10.2.41-1.el7.centos.x86_64.rpm: [Errno 14] HTTP Error 404 - Not Found
    Error downloading packages:
      MariaDB-shared-10.2.41-1.el7.centos.x86_64: [Errno 256] No more mirrors to try.
    Looks like MariaDB 10.2 was installed and not the default MariaDB 10.3 in 123.09beta01
    [1;33;40m--------------------------------------------------------
    (B[m[1;33;40mCheck MariaDB installed RPM Versions:
    (B[m[1;33;40m--------------------------------------------------------
    (B[mMariaDB-compat-10.2.41-1.el7.centos.x86_64
    MariaDB-devel-10.2.41-1.el7.centos.x86_64
    MariaDB-client-10.2.41-1.el7.centos.x86_64
    MariaDB-server-10.2.41-1.el7.centos.x86_64
    MariaDB-common-10.2.41-1.el7.centos.x86_64
    what does the contents of /etc/yum.repos.d/mariadb.repo look like?
    [mariadb]
    name = MariaDB
    baseurl = http://yum.mariadb.org/10.3/centos7-amd64
    gpgkey=https://yum.mariadb.org/RPM-GPG-KEY-MariaDB
    gpgcheck=1
    exclude=MariaDB-Galera-server
  12. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    Damn, thought I had deleted the PW's. Cant get you that file now as destroyed the VPS and starting over - its happened twice now so if I get the same issue ill post up that log before I apply the fix
  13. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    Ok, just installed centminmod - php8.1
    Really weird all the MySql PW's are now all blank in the installer screen
    Will post up logs in a bit
    55,158
    12,249
    3:59 AM
    well I tested 123.09beta01 fresh install and not getting the issue. It could be specific to your VPS server and it's location as something is funky with MariaDB 10.2 being installed instead of 10.3 so could be a MariaDB YUM mirror issue. I'd try on a different VPS host and see if you get the same issue.
  15. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    Screen shot of the no passwords's after fresh install, VPS is Vultr in Sweden
  16. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    55,158
    12,249
    3:59 AM
    You mean you didn't edit those, but they were blank by default ? inspect the full install log not the minimal log to be sure in /root/centminlogs there's 2 versions minimal and full logs
    ls -lahrt /root/centminlogs/ | grep installer
    -rw-r--r--   1 root root 3.7M Dec  7 06:27 installer_071221-010436.log
    -rw-r--r--   1 root root 1.2M Dec  7 06:27 installer_071221-010436_minimal.log
  18. cloud9
    435
    118
    England
    6:59 PM
    1.25.3
    10.6.x
    Correct - Blank on install
    Cleansed log attached - note I didnt cleanse PW as they were not there
    Yes this is the same VPS - just another instance
    Yes a few testing issues, a bit rusty though, Just doing a new Invision on centminmod install ad haven't done one for a good few years
    55,158
    12,249
    3:59 AM
    Interesting issue, could be related to openssl as that is what is used to generate those specific passwords and I noticed in your logs these lines related to openssl that I don't see in mine
    Extra arguments given.
    rand: Use -help for summary.
    what versions of openssl are installed on your problematic VPS?
    what is output for these commands
    which openssl
    openssl version -a
    /opt/openssl/bin/openssl version -a
    echo -e "$(openssl rand 31 -base64 | tr -dc 'a-zA-Z0-9')\n"
    echo -e "$(/opt/openssl/bin/openssl rand 31 -base64 | tr -dc 'a-zA-Z0-9')\n"
    for posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags :)
    examples
    which openssl
    /usr/bin/openssl
    openssl version -a
    OpenSSL 1.0.2k-fips  26 Jan 2017
    built on: reproducible build, date unspecified
    platform: linux-x86_64
    options:  bn(64,64) md2(int) rc4(16x,int) des(idx,cisc,16,int) idea(int) blowfish(idx)
    compiler: gcc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DKRB5_MIT -m64 -DL_ENDIAN -Wall -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches   -m64 -mtune=generic -Wa,--noexecstack -DPURIFY -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DRC4_ASM -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM -DECP_NISTZ256_ASM
    OPENSSLDIR: "/etc/pki/tls"
    engines:  rdrand dynamic
    OpenSSL 1.1.1l  24 Aug 2021
    built on: Tue Dec 14 14:55:51 2021 UTC
    options:  bn(64,64) rc4(16x,int) des(int) idea(int) blowfish(ptr)
    compiler: ccache /opt/rh/devtoolset-10/root/usr/bin/gcc -fPIC -pthread -m64 -Wa,--noexecstack -O3 -m64 -march=native -Wimplicit-fallthrough=0 -Wno-implicit-function-declaration -Wno-int-conversion -Wno-error=unused-result -fcode-hoisting -Wno-cast-function-type -Wno-format-extra-args -Wformat=0 -pipe -DOPENSSL_USE_NODELETE -DL_ENDIAN -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DRC4_ASM -DMD5_ASM -DAESNI_ASM -DVPAES_ASM -DGHASH_ASM -DECP_NISTZ256_ASM -DX25519_ASM -DPOLY1305_ASM -DNDEBUG
    OPENSSLDIR: "/opt/openssl"
    ENGINESDIR: "/opt/openssl/lib/engines-1.1"
    Seeding source: os-specific
    Gdp4c2AKPZhbZX9ezRbb68i2Bsfbo1oQZyZyjLQ
    looks like the problem is the install is picking up Nginx's openssl 1.1.1 version
    Looks like number of characters needs to be the last argument
    /opt/openssl/bin/openssl rand -base64 32
    2XZVoAMP+AfI8rEDdZFRN5ZzPdhxKUoMw/yQFvnnk
    oPq5S/JyIBA3m/6Z6xZPA9LPD2Bt1hYdmx2JA/isdxg=
    55,158
    12,249
    3:59 AM
    FYI, updated 123.09beta01 with the fix to ensure system /usr/bin/openssl is used for password generation. So try a fresh install
