Hello After updating to the latest beta Centminmod version i got a prompt to run this: Code: yum update --disableplugin=priorities --enablerepo=remi,city-fan.org When it start installing i got this problem warning: Code: Warning: RPMDB altered outside of yum. ** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows: varnish-release-4.1-2.el7.noarch is a duplicate with varnish-release-3.0-1.el6.noarch I never install or do anything related varnish ......
123.09beta01 added varnish 4.1 yum repo so if you did centmin.sh menu option 4 or 5 and answered yes to yum check, it would sync 123.09beta01 latest yum setup which includes adding varnish cache 4.1 yum repo. but not sure why varnish for centos 7 is installed on varnish meant for centos 6 is this a centos 7 or 6 server ?
if it's centos 7 system just remove the varnish-release-3.0 centos 6 instance Code (Text): yum remove varnish-release-3.0
