Beta Branch force IPv4 connection for all wget & curl calls
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 4, 2017.
    49,025
    11,232
    1:36 PM
    49,025
    11,232
    1:36 PM
    just fixed a bug in 123.09beta01 due to change to force wget and curl to use IPv4 only Beta Branch - force IPv4 connection for all wget & curl calls due to -4 flag not liking being placed after -n flag in wget
    For existing 123.09beta01 installs which were installed more than 24hrs ago, to update your server's 123.09beta01 code, run centmin.sh menu option 23, submenu option 2.
    For 123.09beta01 installs made in last 24hrs of this post, you will need to run a quick script to fix up the missing stuff due to wget failing to download during the bug
    run command below to run wget-fix.sh which will patch up what's missing
    curl -sL https://gist.github.com/centminmod/eb59205e4a2b3ecc563fbcbc9af820a4/raw/wget-fix.sh | bash
    example output
    update centmin mod local code
    No local changes to save
    Already up-to-date.
    install wp-cli
    installing...
    2017-07-04 21:35:20 URL:http://geolite.maxmind.com/download/geoip/database/GeoLiteCity.dat.gz [12573228/12573228] -> "/usr/share/GeoIP/GeoLiteCity.dat.gz" [1]
    check /usr/share/GeoIP/GeoIPCity.dat
    -rw-r--r-- 1 root root 19M Jul  4 19:00 /usr/share/GeoIP/GeoIPCity.dat
    check pflogsumm command
    Postfix log summaries for Jul  4
    Grand Totals
    messages
          0   received
          0   delivered
          0   forwarded
          0   deferred
          0   bounced
          0   rejected (0%)
          0   reject warnings
          0   held
          0   discarded (0%)
          0   bytes received
          0   bytes delivered
          0   senders
          0   sending hosts/domains
          0   recipients
          0   recipient hosts/domains
    Per-Hour Traffic Summary
        time          received  delivered   deferred    bounced     rejected
        0000-0100           0          0          0          0          0
        0100-0200           0          0          0          0          0
        0200-0300           0          0          0          0          0
        0300-0400           0          0          0          0          0
        0400-0500           0          0          0          0          0
        0500-0600           0          0          0          0          0
        0600-0700           0          0          0          0          0
        0700-0800           0          0          0          0          0
        0800-0900           0          0          0          0          0
        0900-1000           0          0          0          0          0
        1000-1100           0          0          0          0          0
        1100-1200           0          0          0          0          0
        1200-1300           0          0          0          0          0
        1300-1400           0          0          0          0          0
        1400-1500           0          0          0          0          0
        1500-1600           0          0          0          0          0
        1600-1700           0          0          0          0          0
        1700-1800           0          0          0          0          0
        1800-1900           0          0          0          0          0
        1900-2000           0          0          0          0          0
        2000-2100           0          0          0          0          0
        2100-2200           0          0          0          0          0
        2200-2300           0          0          0          0          0
        2300-2400           0          0          0          0          0
    Host/Domain Summary: Message Delivery
     sent cnt  bytes   defers   avg dly max dly host/domain
    Host/Domain Summary: Messages Received
     msg cnt   bytes   host/domain
    Senders by message count: none
    Recipients by message count: none
    Senders by message size: none
    Recipients by message size: none
    message deferral detail: none
    message bounce detail (by relay): none
    message reject detail: none
    message reject warning detail: none
    message hold detail: none
    message discard detail: none
    smtp delivery failures: none
    Warnings: none
    Fatal Errors: none
    Panics: none
    Master daemon messages
          1   daemon started -- version 2.10.1, configuration /etc/postfix
    fixes completed
    What's missing is just geoip database download, wp-cli install and pflogsumm command which is aliased via postfixlog command to report postfix daily stats for email i.e.
    postfixlog
    Grand Totals
    messages
          0   received
          0   delivered
          0   forwarded
          0   deferred
          0   bounced
          0   rejected (0%)
          0   reject warnings
          0   held
          0   discarded (0%)
          0   bytes received
          0   bytes delivered
          0   senders
          0   recipients
        0000-0100           0          0          0          0          0
        0100-0200           0          0          0          0          0
        0200-0300           0          0          0          0          0
        0300-0400           0          0          0          0          0
        0400-0500           0          0          0          0          0
        0500-0600           0          0          0          0          0
        0600-0700           0          0          0          0          0
        0700-0800           0          0          0          0          0
        0800-0900           0          0          0          0          0
        0900-1000           0          0          0          0          0
        1000-1100           0          0          0          0          0
        1100-1200           0          0          0          0          0
        1200-1300           0          0          0          0          0
        1300-1400           0          0          0          0          0
        1400-1500           0          0          0          0          0
        1500-1600           0          0          0          0          0
        1600-1700           0          0          0          0          0
        1700-1800           0          0          0          0          0
        1800-1900           0          0          0          0          0
        1900-2000           0          0          0          0          0
        2000-2100           0          0          0          0          0
        2100-2200           0          0          0          0          0
        2200-2300           0          0          0          0          0
        2300-2400           0          0          0          0          0
    Warnings: none
    Fatal Errors: none
    Panics: none
