Xenforo Fonttools installation for using it in Font Awesome Manager addon
Discussion in 'Forum software usage' started by Dnyan, Jun 14, 2021.
  1. Dnyan
    Dnyan Member
    106
    24
    7:40 PM
    1.17.8
    10.3.22
    I am writing this tutorial kind of post just to make help of myself in future in cases if i mess with something.
    Font Awesome Manager addon can be found at below link
    Beta - Font Awesome Manager
    First do install python 3, the instructions are well written in below article
    Sysadmin - CentOS 7 Python 2.7 will reach the end of its life on January 1st, 2020
    In case if your server GCC version is below 8 or get error while making
    make changes to below command given in above article for python installation.
    if [[ "$(nproc)" -le '2' ]]; then time ./configure --prefix=/opt/python${python_prefixver} --with-openssl=/usr; else time ./configure --enable-optimizations --prefix=/opt/python${python_prefixver} --with-openssl=/usr; fi
    do remove
    so it will be
    if [[ "$(nproc)" -le '2' ]]; then time ./configure --prefix=/opt/python${python_prefixver} --with-openssl=/usr; else time ./configure --prefix=/opt/python${python_prefixver} --with-openssl=/usr; fi
    Then do install Fonttools with following command
    pip3 install fonttools[woff]
    Once you installed the fonttools
    Simple path to pyftsubset in above case of installation
    /home/python_projects/myproject/bin/pyftsubset
    now you can use pyftsubset in FAM.
    55,797
    12,271
    12:10 AM
    FYI, you should be fine with just using Python 3.6 supported side by side with Python 2.7 on CentOS 7
    Just run the python 3.6 installer addon for Centmin Mod
    /usr/local/src/centminmod/addons/python36_install.sh
    Then you can call that version of pip via pip3.6 command
    pip3.6 install -U pip
    pip3.6 install fonttools
    pip3.6 install fonttools[woff]
    WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
    Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
    To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
    Collecting fonttools
      Downloading fonttools-4.24.4-py3-none-any.whl (854 kB)
         |████████████████████████████████| 854 kB 19.9 MB/s
    Installing collected packages: fonttools
    Successfully installed fonttools-4.24.4
    WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: https://pip.pypa.io/warnings/venv
    Requirement already satisfied: fonttools[woff] in /usr/local/lib/python3.6/site-packages (4.24.4)
    Collecting brotli>=1.0.1
      Downloading Brotli-1.0.9-cp36-cp36m-manylinux1_x86_64.whl (357 kB)
         |████████████████████████████████| 357 kB 13.3 MB/s
    Collecting zopfli>=0.1.4
      Downloading zopfli-0.1.8-cp36-cp36m-manylinux1_x86_64.whl (41 kB)
         |████████████████████████████████| 41 kB 1.6 MB/s
    Installing collected packages: zopfli, brotli
    Successfully installed brotli-1.0.9 zopfli-0.1.8
    FYI, the old script wrapper message is just telling you to change from
    to
    python3.6 -m pip install fonttools
    python3.6 -m pip install fonttools[woff]
  3. Chris
    Chris Member
    51
    10:10 AM
    1.7
    What is the path to the directory 'pyftsubset' if we follow your line @eva2000
    55,797
    12,271
    12:10 AM
    tried just running
    updatedb
    locate pyftsubset
    edit, using verbose flag will show you where pyftsubset is installed too
    python3.6 -m pip install fonttools --force --verbose
    Using pip 21.2.4 from /usr/local/lib/python3.6/site-packages/pip (python 3.6)
      Using cached fonttools-4.26.2-py3-none-any.whl (870 kB)
      Attempting uninstall: fonttools
        Found existing installation: fonttools 4.26.2
        Uninstalling fonttools-4.26.2:
          Removing file or directory /usr/local/bin/fonttools
          Removing file or directory /usr/local/bin/pyftmerge
          Removing file or directory /usr/local/bin/pyftsubset
          Removing file or directory /usr/local/bin/ttx
          Removing file or directory /usr/local/lib/python3.6/site-packages/fontTools/
          Removing file or directory /usr/local/lib/python3.6/site-packages/fonttools-4.26.2.dist-info/
          Removing file or directory /usr/local/share/man/man1/ttx.1
          Successfully uninstalled fonttools-4.26.2
      changing mode of /usr/local/bin/fonttools to 775
      changing mode of /usr/local/bin/pyftmerge to 775
      changing mode of /usr/local/bin/pyftsubset to 775
      changing mode of /usr/local/bin/ttx to 775
    Successfully installed fonttools-4.26.2
  5. rdan
    1,412
    10:10 PM
    Any clue about this error on the default python 2.7?
    # pip install fonttools[woff]
    DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
    Requirement already satisfied: fonttools[woff] in /usr/lib/python2.7/site-packages (3.44.0)
    Collecting brotli>=1.0.1; platform_python_implementation != "PyPy" and extra == "woff"
      Using cached Brotli-1.0.9-cp27-cp27mu-manylinux1_x86_64.whl (355 kB)
    Collecting zopfli>=0.1.4; extra == "woff"
      Using cached zopfli-0.1.9.zip (79 kB)
        ERROR: Command errored out with exit status 1:
         command: /usr/bin/python2 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-_qaNcl/zopfli/setup.py'"'"'; __file__='"'"'/tmp/pip-install-_qaNcl/zopfli/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-rNXMGY
             cwd: /tmp/pip-install-_qaNcl/zopfli/
        Complete output (23 lines):
        Couldn't find index page for 'setuptools_scm' (maybe misspelled?)
        No local packages or download links found for setuptools-scm
        Traceback (most recent call last):
          File "<string>", line 1, in <module>
          File "/tmp/pip-install-_qaNcl/zopfli/setup.py", line 90, in <module>
            setup_requires=["setuptools_scm"],
          File "/usr/lib64/python2.7/distutils/core.py", line 112, in setup
            _setup_distribution = dist = klass(attrs)
          File "/usr/lib/python2.7/site-packages/setuptools/dist.py", line 265, in __init__
            self.fetch_build_eggs(attrs.pop('setup_requires'))
          File "/usr/lib/python2.7/site-packages/setuptools/dist.py", line 289, in fetch_build_eggs
            parse_requirements(requires), installer=self.fetch_build_egg
          File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 618, in resolve
            dist = best[req.key] = env.best_match(req, self, installer)
          File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 862, in best_match
            return self.obtain(req, installer) # try and download/install
          File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 874, in obtain
            return installer(requirement)
          File "/usr/lib/python2.7/site-packages/setuptools/dist.py", line 339, in fetch_build_egg
            return cmd.easy_install(req)
          File "/usr/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 617, in easy_install
            raise DistutilsError(msg)
        distutils.errors.DistutilsError: Could not find suitable distribution for Requirement.parse('setuptools-scm')
    ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
    55,797
    12,271
    12:10 AM
  7. rdan
    1,412
    10:10 PM
    Website says:
    FontTools requires Python 3.7 or later.
    fonttools
    55,797
    12,271
    12:10 AM
    Have you tried with Python 3.6 in above linked instructions ?
    55,797
    12,271
    12:10 AM
    FYI, fonttools 4.28+ need Python 3.7, but CentOS python 3.6 installs fonttools 4.27.1 fonttools
  10. rdan
    1,412
    10:10 PM
    Using this addon on XF2.2 and CentOS 7.9 default Python 2.7 (without the extra Python 3.6 install)
    I can just use pyftsubset with these pip install commands:
  11. rdan
    1,412
    10:10 PM
    By doing so... Transfonter.org vs pyftsubset local with Brotli:
    File size decrease from 16.2kb to 15kb.
    Nice :)
    55,797
    12,271
    12:10 AM
  13. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    4:10 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    55,797
    12,271
    12:10 AM
    No need to delete if you followed my post above, you'd just have fonttools installed in 2 locations
    but if you installed with below
    I believe you can uninstall via
    python3.6 -m pip uninstall fonttools
  15. MaximilianKohler
    MaximilianKohler Member
    203
    9
    7:10 AM
    I'm seeing 3 different sets of instructions in this thread.
    1. The OP.
    2. rdan's method.
    3. eva's method.
    What's the deal? I guess I'll go with eva's method...
