Beta Branch prep nginx for Cloudflare Post-Quantum KEX support in 130.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 1, 2023.
    12,579
    9:06 PM
    - prepare Centmin Mod Nginx to optionally support Cloudflare Post-Quantum key exchange/agreement support allowing Cloudflare to connect to Centmin Mod Nginx origins using Post-Quantum key exchange curve X25519Kyber768Draft00 https://blog.cloudflare.com/post-quantum-to-origins/
    - update default nginx.conf's main_json JSON log format to also log ssl_curve, ssl_curves, ssl_session_reused values for visitor requests to be able to confirm if Cloudflare is indeed connecting to Centmin Mod Nginx origin servers via X25519Kyber768Draft00 when Centmin Mod switches from default OpenSSL crypto library to BoringSSL as outlined on documented test Centmin Mod Nginx with Post-Quantum support via BoringSSL
    130.00beta01 branch
    Support Centmin Mod
    12,579
    9:06 PM
    Centmin Mod LEMP stack which supports various Nginx crypto libraries - BoringSSL, OpenSSL 1.1.1 (default), OpenSSL 3.0/3.1, LibreSSL, QuicTLS OpenSSL 1.1.1/3.0/3.1 and Quiche/BoringSSL for HTTP/3 QUIC.
    Example of Centmin Mod Nginx switching from default OpenSSL 1.1.1 to BoringSSL to enable Post-Quantum key exchange support using SSL curve X25519Kyber768Draft00 - preparing for Cloudflare being able to connect to Centmin Mod Nginx origins via more secure Post-Quantum key exchange as outlined at https://blog.cloudflare.com/post-quantum-to-origins/.
    1. Switch from default Centmin Mod Nginx built with OpenSSL 1.1.1 crypto library to BoringSSL crypto library by enabling BoringSSL support, by setting in the persistent config file /etc/centminmod/custom_config.inc
    BORINGSSL_SWITCH='y'
    2. Run cmupdate and centmin.sh menu option 4 commands to update local Centmin Mod code to latest and then recompile Centmin Mod Nginx with BoringSSL
    cmupdate
    centmin
        Centmin Mod Menu 130.00beta01 centminmod.com
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  Option Being Revised (TBA)
    7).  Option Being Revised (TBA)
    8).  Option Being Revised (TBA)
    9).  Option Being Revised (TBA)
    14). SELinux disable
    16). Change SSHD Port Number
    17). Multi-thread compression: zstd,pigz,pbzip2,lbzip2
    20). NSD Install/Re-Install
    21). Data Transfer (TBA)
    24). Exit
    Enter option [ 1 - 24 ] 4
    Nginx Upgrade - Would you like to continue? [y/n] y
    Current Nginx Version: 1.24.0 (260923-074355-almalinux9-332935a-br-659b4b3)
    Install which version of Nginx? (version i.e. type 1.25.2): 1.25.2
    Do you still want to continue? [y/n] y
    Centmin Mod Nginx built with optional BoringSSL crypto library. You can ignore warning for nginx: [warn] "ssl_stapling" ignored, not supported as BoringSSL doesn't support OSCP Stapling which isn't a problem if you have Cloudflare in front of Centmin Mod Nginx and only need Cloudflare to talk to Centmin Mod Nginx origin using Post-Quantum key exchange :)
    Check that Nginx version output shows built with OpenSSL 1.1.1 (compatible; BoringSSL) (running with BoringSSL)
    nginx -V
    nginx version: nginx/1.25.2 (290923-192121-almalinux9-332935a-br-659b4b3)
    built by gcc 12.2.1 20221121 (Red Hat 12.2.1-7) (GCC)
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-Wl,-E -L/usr/local/zlib-cf/lib
    -L/opt/boringssl/.openssl/lib -lcrypto -lssl -L/usr/local/nginx-dep/lib -lrt
    -ljemalloc -Wl,-z,relro
    -Wl,-rpath,/usr/local/zlib-cf/lib:/opt/boringssl/.openssl/lib:/usr/local/nginx-d
    ep/lib -flto=8 -fuse-ld=gold' --with-cc-opt='-I/opt/boringssl/.openssl/include
    -I/usr/local/zlib-cf/include -I/usr/local/nginx-dep/include -m64 -march=native
    -g -O3 -fstack-protector-strong -flto=8 -fuse-ld=gold --param=ssp-buffer-size=4
    -Wformat -Werror=format-security -Wno-pointer-sign -Wimplicit-fallthrough=0
    -Wno-implicit-function-declaration -Wno-int-conversion -Wno-error=unused-result
    -Wno-unused-result -fcode-hoisting -Wno-cast-function-type
    -Wno-format-extra-args -Wp,-D_FORTIFY_SOURCE=2'
    --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf
    --build=290923-192121-almalinux9-332935a-br-659b4b3 --with-compat
    --without-pcre2 --with-http_stub_status_module --with-http_secure_link_module
    --with-libatomic --with-http_gzip_static_module
    --add-dynamic-module=../ngx_brotli --add-module=../ngx_http_geoip2_module
    --with-http_sub_module --with-http_addition_module
    --with-http_image_filter_module=dynamic --with-http_geoip_module
    --with-stream_geoip_module --with-stream_realip_module
    --with-stream_ssl_preread_module --with-threads --with-stream
    --with-stream_ssl_module --with-http_realip_module
    --add-dynamic-module=../ngx-fancyindex-0.4.2
    --add-module=../ngx_cache_purge-2.5.1
    --add-dynamic-module=../ngx_devel_kit-0.3.2
    --add-dynamic-module=../set-misc-nginx-module-0.33
    --add-dynamic-module=../echo-nginx-module-0.63
    --add-module=../redis2-nginx-module-0.15
    --add-module=../ngx_http_redis-0.4.0-cmm --add-module=../memc-nginx-module-0.19
    --add-module=../srcache-nginx-module-0.33
    --add-dynamic-module=../headers-more-nginx-module-0.34 --with-pcre-jit
    --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module
    --with-http_v2_module
    nginx -t
    ldd /usr/local/sbin/nginx
           linux-vdso.so.1 (0x00007ffd7494b000)
           libcrypto.so => /opt/boringssl/.openssl/lib/libcrypto.so (0x00007fa90b0ba000)
           libssl.so => /opt/boringssl/.openssl/lib/libssl.so (0x00007fa90b04c000)
           libjemalloc.so.2 => /lib64/libjemalloc.so.2 (0x00007fa90ac00000)
           libcrypt.so.2 => /lib64/libcrypt.so.2 (0x00007fa90b005000)
           libmaxminddb.so.0 => /usr/local/nginx-dep/lib/libmaxminddb.so.0 (0x00007fa90affe000)
           libpcre.so.1 => /usr/local/nginx-dep/lib/libpcre.so.1 (0x00007fa90af85000)
           libGeoIP.so.1 => /lib64/libGeoIP.so.1 (0x00007fa90af46000)
           libatomic_ops.so.1 => /lib64/libatomic_ops.so.1 (0x00007fa90af41000)
           libc.so.6 => /lib64/libc.so.6 (0x00007fa90a800000)
           libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fa90a400000)
           libm.so.6 => /lib64/libm.so.6 (0x00007fa90ab25000)
           libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fa90af24000)
           /lib64/ld-linux-x86-64.so.2 (0x00007fa90b2b4000)
    Now that you have Centmin Mod Nginx with BoringSSL, for Post-Quantum key exchange to work you need:
    1. Nginx to have ssl_ecdh_curve X25519Kyber768Draft00:X25519; set in only one Nginx HTTPS vhost where listen directive has set default_server. Don't set default_server in other Nginx HTTPS vhosts - once only in one Nginx HTTPS vhost instance's listen directive.
    For Nginx 1.25
      listen 443 ssl default_server;
      http2 on;
    For Nginx 1.24
      listen 443 ssl http2 default_server;
    2. The following directives in Nginx HTTPS vhosts
    Centmin Mod already has an include file for/usr/local/nginx/conf/ssl_include.conf which has the following. Make sure TLSv1.3 is set.
    ssl_protocols  TLSv1.2 TLSv1.3;
    Ensure you restart Nginx server
    systemctl restart nginx
    or via Centmin Mod command shortcut
    ngxrestart
    Test using BoringSSL bssl client shows Post-Quantum curve being used ECDHE group: X25519Kyber768Draft00. Change very first line domain= variable to assign your domain name and then run second command
    domain=domain.com
    echo | bssl client -server-name $domain -connect $domain:443 -curves X25519:X25519Kyber768Draft00 -debug
    example output
    domain=domain.com
    Connecting to myserverip:443
    Handshake started.
    Handshake progress: TLS client enter_early_data
    Handshake progress: TLS client read_server_hello
    Handshake progress: TLS 1.3 client read_hello_retry_request
    Handshake progress: TLS 1.3 client read_server_hello
    Handshake progress: TLS 1.3 client read_encrypted_extensions
    Handshake progress: TLS 1.3 client read_certificate_request
    Handshake progress: TLS 1.3 client read_server_certificate
    Handshake progress: TLS 1.3 client read_server_certificate_verify
    Handshake progress: TLS 1.3 client read_server_finished
    Handshake progress: TLS 1.3 client send_end_of_early_data
    Handshake progress: TLS 1.3 client send_client_encrypted_extensions
    Handshake progress: TLS 1.3 client send_client_certificate
    Handshake progress: TLS 1.3 client complete_second_flight
    Handshake progress: TLS 1.3 client done
    Handshake progress: TLS client finish_client_handshake
    Handshake progress: TLS client done
    Handshake done.
    Connected.
      Version: TLSv1.3
      Resumed session: no
      Cipher: TLS_AES_128_GCM_SHA256
      Signature algorithm: ecdsa_secp256r1_sha256
      Secure renegotiation: yes
      Extended master secret: yes
      Next protocol negotiated:
      ALPN protocol:
      OCSP staple: no
      SCT list: no
      Early data: no
      Encrypted ClientHello: no
      Cert subject: CN = domain.com
      Cert issuer: C = US, O = Let's Encrypt, CN = R3
    Seems Cloudflare already has determined my test Centmin Mod Nginx origin with BoringSSL has Post-Quantum key exchange support and is communicating with my origin via X25519Kyber768Draft00 :)
    From my Centmin Mod Nginx access logs in JSON format shows ssl_curve for the request from Cloudflare orange cloud enabled site = X25519Kyber768Draft00
    cat access.json | jq -c | tail -1 | jq -r
      "msec": "1696111325.536",
      "connection": "1",
      "connection_requests": "1",
      "pid": "1743334",
      "request_id": "e52516e5a82687420646a8b81c0d8e76",
      "request_length": "650",
      "remote_addr": "172.xxx.xxx.xxx",
      "remote_user": "",
      "remote_port": "10544",
      "time_local": "30/Sep/2023:22:02:05 +0000",
      "time_iso8601": "2023-09-30T22:02:05+00:00",
      "request": "GET / HTTP/2.0",
      "request_uri": "/",
      "args": "",
      "status": "304",
      "body_bytes_sent": "0",
      "bytes_sent": "177",
      "http_referer": "",
      "http_user_agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 OPR/102.0.0.0",
      "http_x_forwarded_for": "2a09:xxx:xxx:xxx:xxx:xxx",
      "http_host": "domain.com",
      "server_name": "domain.com",
      "request_time": "0.000",
      "upstream": "",
      "upstream_connect_time": "",
      "upstream_header_time": "",
      "upstream_response_time": "",
      "upstream_response_length": "",
      "upstream_cache_status": "",
      "ssl_protocol": "TLSv1.3",
      "ssl_session_reused": ".",
      "ssl_cipher": "TLS_AES_128_GCM_SHA256",
      "ssl_curve": "X25519Kyber768Draft00",
      "ssl_curves": "",
      "scheme": "https",
      "request_method": "GET",
      "server_protocol": "HTTP/2.0",
      "pipe": ".",
      "gzip_ratio": "",
      "http_cf_ray": "80efbf881ea0e9bf-BNE",
      "http_cf_worker": "",
      "http_cf_request_id": "",
      "http_cf_railgun": "",
      "http_accept": "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
    Note though BoringSSL does not support dual RSA + ECDSA A SSL certs using DUALCERTS=y setting. So you would only serve one set of SSL certs with it.
  3. buik
    2,044
    527
    Flanders
    1:06 PM
    BoringSSL is unstable and even discouraged by the developers themselves from running in production.
    Nice to see that Cloudflare has forked BoringSSL, but their full fork so with dual cert, stapling etc functionality they have not made public. In addition, X25519Kyber768Draft00 is only at draft00 so very experimental. I cannot think of any reason to use this experimental code on top of BoringSSL on a well-run site. Nice for a test server but that's really all.
    12,579
    9:06 PM
    Yup only using for testing Cloudflare to Centmin Mod Nginx origin support for Post-Quatum key exchange connections. Still a long way to go for production use.
    12,579
    9:06 PM
  6. buik
    2,044
    527
    Flanders
    1:06 PM
    I definitely don't want to be the bad guy again and again, but be honest with you. And have challenged it more often. Since your time is short.
    Please focus on EL8 compatibility and beyond, but not on experimental features like this. Since CMM, none beta is not compatible with > EL7, and EL7 expires within a few months. There is virtually no dedi, yet new VPS to be started with version 7.
    12,579
    9:06 PM
    I get where you're coming from. It's all connected - as I have to focus on technologies that are also beneficial to my paid consulting client work too that pays my bills. And part of that work is consulting on optimizing clients Cloudflare setups for their web sites. Having advanced Cloudflare setup and configuration knowledge for all Cloudflare products and services is part of my paid work :)
    Also this was tested on EL8/EL9 oses so it's still testing for future compatibility of Nginx BoringSSL routines and fixed bugs revealed in Nginx routine ;) And is now part of automated Nginx + BoringSSL routine tests I have setup to make future testing easier for EL8+ and beyond. I have almost all Centmin Mod routines setup for automated testing soon. This will help future testing and development. Again as I said, it's all connected :D
    Example of the automated testing for EL8/EL9 - one test run can test AlmaLinux vs RockyLinux vs Oracle Linux all at same time. This automated testing has helped me catch bugs and improve routines in EL8/EL9 :cool:
    Screenshot_2023-10-04-01-05-48-515-edit_com.brave.browser.jpg Screenshot_2023-10-04-01-04-42-071-edit_com.brave.browser.jpg Screenshot_2023-10-04-01-04-56-336-edit_com.brave.browser.jpg Screenshot_2023-10-04-01-05-21-602-edit_com.brave.browser.jpg Screenshot_2023-10-04-01-30-05-110-edit_com.brave.browser.jpg
  8. pamamolf
    4,128
    2:06 PM
    EL8 support seems to me too as an emergency as i am afraid if something bad happened on existing server, maybe Centos 7 will not be an option anymore. Also for new servers, Centos 7 is not easy to find and installing a new server on an OS that expires very soon doesn't feel great.
    But i completely understand your work flow and i can't complain of course :)
    12,579
    9:06 PM
    That's what the currently private 130.00beta01 EL8+ compatible installer is for. That EL8+ installer code isn't going to change much whether it's in private beta or eventual public beta right now. In either case of private or public EL8+ beta, if bugs arise they will have the same fixes.
    If you are concerned with the quality of the private 130.00beta01 EL8+ beta, then it makes more sense to do more in-depth testing for your specific usage cases now during the private beta and report any bugs, than waiting on the public EL8+ beta announcement as you'd have less Centmin Mod users competing for my time/responses during the private beta testing ;)
  10. buik
    2,044
    527
    Flanders
    1:06 PM
    I have a lot of respect from where you come from, and from your background. I worked with various IT background's before.
    Since there are only about, around 8 months left until the end of CentOS 7, the "code isn't going to change much". And you have stated more often, that few of the top c.q. of the largest Xenforo forums running on CMM.
    And a very simple reason, a large site or forum is not easily transferred, it takes time and this time is running out.
    I sincerely recommend on CMM8, effective immediately of now, at least open CMM8 as an open beta available right now.
    The closed beta has been available for over a year and given @pamamolf makes an "emergency" request, it seems more than reasonable to me to reveal the beta to the general public.
    Given that you wish to receive more "test" data from this particular beta. Is this once more, a legitimate reason to reveal the beta.
    12,579
    9:06 PM
    Public EL8 beta is coming soon. It's always been planned for :)
    12,579
    9:06 PM
    perfect example of this is @MaximilianKohler recent post for his specific usage and PostgreSQL requirements https://community.centminmod.com/th...w-vhost-in-addition-to-a-forum-xenforo.24123/ is essentially a bug report and reminder for me as I forgot to add PostgreSQL routines for EL8 and EL9 compatibility. So now have added them https://community.centminmod.com/th...16-add-el8-el9-support-in-130-00beta01.24124/ and also added automated tests for PostgreSQL routines for EL8 and EL9 :) With automated testing now in place, PostgreSQL routines will never be left out of EL8/EL9 and future testing :D
