Beta Branch fix pure-ftpd login issues in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 7, 2024.
    55,944
    8:47 PM
    - revert nginx user's uid and gid defaults from 956 to 1068 to allow pure-ftpd virtual ftp user logins. Fresh installs will have it already fixed
    - existing users can run cmupdate, then run and exist centmin.sh menu to apply changes and verify nginx uid/gid is not set to 1068 using command:
    id nginx
    - this update also added a script /usr/local/src/centminmod/tools/switch_pureftpd_uid.sh to manually update Centmin Mod nginx virtual pure-ftpd username's nginx uid/gid. The above cmupdate + centmin.sh menu run and exit should auotmatically run this script too but if it didn't and your id nginx returns 1068 but pure-pw show username command shows UID/GID as still not 1068, you can set it via script
    /usr/local/src/centminmod/tools/switch_pureftpd_uid.sh -u 1068 -g 1068
    then verify pure-ftpd user via
    pure-pw show YOURFTP_USERNAME
    140.00beta01 branch
