CentOS 7 Beta Branch fix pure-ftpd configuration routine for missing files
Discussion in 'Centmin Mod Github Commits' started by eva2000, Apr 1, 2015.
    49,874
    11,485
    8:47 AM
    49,874
    11,485
    8:47 AM
    For existing Centmin Mod .08 beta 02 users, you can run this command line to run a script to try and fix pure-ftpd and then you will need to manually re-create all pure-ftpd virtual FTP users as per the instructions at end of the script output
    run command/script
    curl -sL https://bitbucket.org/snippets/eva2000/B89b/raw/master/pureftp_fix.sh | bash
    example of output and instructions for manually re-create all pure-ftpd virtual FTP users
    ensure TLS Cipher preference protects against poodle attacks
    create /etc/pure-ftpd/pureftpd.passwd
    check tweaks in /etc/pure-ftpd/pure-ftpd.conf
    VerboseLog                  yes
    UnixAuthentication            yes
    # UnixAuthentication can be used only once, but they can be combined
    # together. For instance, if you use MySQLConfigFile, then UnixAuthentication,
    PassivePortRange    3000 3050
    CreateHomeDir               yes
    # 0 : disable SSL/TLS encryption layer (default).
    # 2 : refuse connections that don't use SSL/TLS security mechanisms,
    # 1) Your server has been compiled with SSL/TLS support (--with-tls),
    TLS                      2
    TLSCipherSuite           HIGH:MEDIUM:+TLSv1:!SSLv2:!SSLv3
    pure-ftpd installed
    Stopping pure-ftpd: [  OK  ]
    Starting pure-ftpd: [  OK  ]
    check /etc/pure-ftpd/pureftpd.passwd
    -rw------- 1 root root 0 Mar 31 17:52 /etc/pure-ftpd/pureftpd.passwd
    check /etc/pure-ftpd/pureftpd.pdb
    -rw------- 1 root root 2.1K Mar 31 17:52 /etc/pure-ftpd/pureftpd.pdb
    end of output will show
    # Fix completed
    because /etc/pure-ftpd/pureftpd.passwd was missing, you will need to
    manually re-create your pure-ftpd virtual FTP user accounts for existing
    nginx vhost accounts using below 3 commands:
    where YOURUSERNAME = your FTP username
    where YOURDOMAINNAME.com = your existing domain name Nginx vhost
    # 3 commands to manually re-create virtual FTP users
        pure-pw useradd YOURUSERNAME -u nginx -g nginx -d /home/nginx/domains/YOURDOMAINNAME.com
        pure-pw mkdb
        service pure-ftpd restart
