Beta Branch fix phpredis php 7 check routine for 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 8, 2016.
    55,941
    10:58 AM
  2. palPalani
    palPalani Member
    30
    12
    Chennai, IN
    6:28 AM
    Nginx 1.7
    MariaDB 5.5
    Yes, I was talking about GitHub - nrk/phpiredis: PHP extension for Redis based on Hiredis There is php7 support branch: GitHub - nrk/phpiredis at php7 which is actively updated.
    I was used with laravel project and i configured laravel config settings:
    'options' => [
    'connections' => [
    'tcp' => 'Predis\Connection\PhpiredisStreamConnection', // PHP streams
    'unix' => 'Predis\Connection\PhpiredisSocketConnection', // ext-socket
    There is FAQ section, which explains about this extension:
    predis/FAQ.md at v1.1 · nrk/predis · GitHub
    55,941
    10:58 AM
    thanks so only php7 support or php7 branch supports php 5.4-5.6 ?
    I actually had to compile my own custom hiredis 0.13 RPM package ages back as CentOS version is around 0.10 IIRC. So probably 1/2 way there :)
    Will check it out. @Xon you used phpiredis before ?
  4. palPalani
    palPalani Member
    30
    12
    Chennai, IN
    6:28 AM
    Nginx 1.7
    MariaDB 5.5
    55,941
    10:58 AM
  6. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    2:58 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Option 13 is still valid for us who want to install via Centmin?
    55,941
    10:58 AM
  8. Xon
    Xon Active Member
    173
    61
    8:58 AM
    I use phpredis not phpiredis.
    55,941
    10:58 AM
    i see :)
