Beta Branch improve PHPDEBUGMODE='y' mode in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 6, 2025.
    60,097
    12,585
    1:46 AM
    - improve PHPDEBUGMODE='y' mode outlined in https://community.centminmod.com/threads/how-to-guide-for-nginx-php-fpm-debugging.17508/
    When persistent config file temporarily enables PHP debug mode for gdb backtracing troubleshooting PHP :: Generating a gdb backtrace via persistent config file variables set in /etc/centminmod/custom_config.inc
    PHPDEBUGMODE='y'
    AUTODETECPHP_OVERRIDE='y' # ensure all PHP extensions are recompiled
    Then you re‑compile PHP via centmin.sh menu option 5
    Which will do the following:
    1. adds ‑g3 ‑O0 ‑fno‑omit‑frame‑pointer to **CFLAGS/CXXFLAGS**
    2. installs a systemd drop‑in file /etc/systemd/system/php-fpm.service.d/10-coredump.conf to setup LimitCORE=infinity
    3. points kernel.core_pattern to /tmp/core-%e-%p-%t
    4. sets fs.suid_dumpable = 1
    Then to disable PHP debug mode, set persistent config file variables in /etc/centminmod/custom_config.inc:
    PHPDEBUGMODE=n
    This will do the following:
    1. remove the systemd drop‑in /etc/systemd/system/php-fpm.service.d/10-coredump.conf
    2. restore the original kernel.core_pattern & fs.suid_dumpable settings
    3. re‑compile PHP without heavy debug flags
    4. if PHP_CLEAN_COREDUMPS=y (the default) delete stale core files in /tmp
    140.00beta01 branch
