Beta Branch patch Nginx std zlib & Cloudflare zlib for CVE-2022-37434 in 130.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 3, 2022.
    60,128
    12,587
    4:07 PM
    - patch security fix for both standard zlib & Cloudflare zlib libraries used by Nginx for CVE-2022-37434 2116639 – (CVE-2022-37434) CVE-2022-37434 zlib: a heap-based buffer over-read or buffer overflow in inflate in inflate.c via a large gzip header extra field and https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-37434
    - also fix GCC routines for zlib for el9's GCC 11 compatibility
    130.00beta01 branch
    Support Centmin Mod
    60,128
    12,587
    4:07 PM
    Existing users can just run command: cmupdate
    Then run centmin.sh menu option 4 to recompile Nginx's zlib library with the patch.
