Centmin Mod Git Repository Online Status
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jan 28, 2016.
Thread Status:
Not open for further replies.
    59,912
    12,547
    6:14 PM
    This sticky thread was created to provide status updates related to Centmin Mod's official Git repositories in case of downtime etc.
    Centmin Mod LEMP stack's code is officially hosted by two Git hosting providers for public Git repos:
    Github is the main Git repository. However, I have a public backup at Gitlab too and also a private development and third backup repo hosted at Bitbucket too.
    Service Status Pages
    Github
    Github main 123.08stable and 123.09beta01 commit history lists
    Gitlab
    Gitlab main 123.08stable and 123.09beta01 commit history lists
    59,912
    12,547
    6:14 PM
    Centmin Mod Installation By Git
    The installation method for Centmin Mod via Git is basically the same, just the Git cloned url link is either to Github or Gitlab Centmin Mod repositories. So you can make the Git clone link a variable so you can change the variable depending on if you want to clone and pull Github or Gitlab repository code for Centmin Mod.
    Type as root user in SSH these commands, Centmin Mod will have it's install setup at /usr/local/src/centminmod
    Set REPOLINK variable to either Github or Gitlab repo url.
    Use Github
    REPOLINK='https://github.com/centminmod/centminmod.git'
    or
    Use Gitlab
    REPOLINK='https://gitlab.com/centminmod/centminmod.git'
    Then proceed to Git method of install as usual.
    yum -y install git wget nano bc unzip
    cd /usr/local/src
    git clone $REPOLINK centminmod
    cd centminmod
    Then to install either type
    for menu mode run centmin.sh and select menu option 1 to install
    ./centmin.sh
    or for CLI install mode
    ./centmin.sh install
    59,912
    12,547
    6:14 PM
    Existing Installs Git Repo Setting
    From 123.08stable and 123.09beta01 and higher, the Git clone repo url for centmin.sh menu option 23 is controlled via CMGIT variable within centmin.sh which defaults to Github based repo with Gitlab one commented out.
    # Centmin Mod Git Repo URL - primary repo
    # https://github.com/centminmod/centminmod
    CMGIT='https://github.com/centminmod/centminmod.git'
    # Gitlab backup repo
    # https://gitlab.com/centminmod/centminmod
    #CMGIT='https://gitlab.com/centminmod/centminmod.git'
    Switching repositories is as easy as uncommenting the Gitlab one and commenting out Github one
    #CMGIT='https://github.com/centminmod/centminmod.git'
    Then you'd need to run centmin.sh menu option 23, submenu option 1 (if you haven't ran it before) or submenu option 3 to switch branches. You just enter the same branch version you are using so if on 123.08stable, enter 123.08stable or on 123.09beta01, enter 123.09beta01. Switching branches right actually deletes the existing Centmin Mod directory at /usr/local/src/centminmod and sets up a new version via a fresh Git clone so that's why submenu option 3 can switch Git repo sources between Gitlab and Github when needed :)
    59,912
    12,547
    6:14 PM
Thread Status:
