Beta Branch OpenSSL 1.1.1 default in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 26, 2018.
    59,738
    10:27 AM
  2. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    2:27 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    @eva2000
    After upgrade nginx, openssl will be v1.1.1, but, after that, should we also manually update ssl_chipers
    ssl_ciphers TLS13-AES-128-GCM-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-CCM-8-SHA256:TLS13-AES-128-CCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
    Above should replace second row here (in mydomain.com.ssl.conf) :
    # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
      #######################add_header Alternate-Protocol  443:npn-spdy/3;
      #######################spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
    And after that restart nginx
    Also, is there something in my custom_config.inc that is not needed any more, or conflicted with something, or something is missing and should be there?
    What do you think?
    NGINX_LIBBROTLI=y # Brotly extension
    NGXDYNAMIC_BROTLI=y # Brotly dynamic module extension
    NGINX_PAGESPEED=n # nginx page speed
    NGXDYNAMIC_NGXPAGESPEED=n # nginx dynamic page speed
    PHP_MEMCACHE=n # memcache PHP extension
    PHP_MEMCACHED=n # memcached PHP extension
    PHP_PGO='y' # PGO Let It Go - Profile Guided Optimizations for PHP 7
    PHPPGO_INDEXPATH='/home/nginx/domains/pijanitvor.com/public/index.php' # path for PGO training
    AUDITD_ENABLE='y' # Auditd skripta
    RCLONE_ENABLE='y' # Rclone skripta
    NGINX_DEVTOOLSETGCC='y' # umjesto clang ide gcc kompilacija kod nginx
    #DEVTOOLSETEIGHT='y' # ide 8.x verzija gcc kompilacije umjesto defaultne 5.x ili 6.x ili 7.x
    LIBRESSL_SWITCH='n' # umjesto LibreSSL ide OpenSSL
    CLOUDFLARE_ZLIB='y' # enable Cloudflare zlib performance library by default for Nginx zlib
    DEVTOOLSETSEVEN='y' # ide 7.x verzija gcc kompilacije umjesto defaultne 5.x ili 6.x
    CLANG='n' # potrebno za gcc kompilaciju nginx
    CRYPTO_DEVTOOLSETGCC='y' # newer Intel GCC
    NGX_LDGOLD='y' # Nginx support for using ld.gold linker
    NGX_GSPLITDWARF='y' # Nginx support for using ld.gold linker
    PHP_GSPLITDWARF='y' # Nginx/php support for using ld.gold linker
    NGINX_ZLIBCUSTOM='y' # add custom zlib 1.2.11+ version support to Nginx compiles - https://goo.gl/1WNZcH
    #NGINX_HPACK='y' # enabling HPACK for Nginx
    NGINX_DYNAMICTLS='y' # add Nginx Dynamic TLS Cloudflare Patch - http://bit.ly/2EYzhk7
    NGINXPATCH='y' # add Nginx Dynamic TLS Cloudflare Patch - http://bit.ly/2EYzhk7
    NGINX_GEOIPTWOLITE='y' # GeoIP2 Lite nginx module
    NGXDYNAMIC_GEOIPTWOLITE='y' # GeoIP2 Lite nginx module
    ENABLE_MARIADBTENTWOUPGRADE='y' # enabling upgrade MariaDB from 10.1.x to 10.2.x
    59,738
    10:27 AM
    yes manual update needed see 2nd post at OpenSSL - OpenSSL 1.1.1 Released with TLS 1.3 Support
    don't need these as they're 123.09beta01 defaults
