Stable Branch add cmsec security check framework for kernel CVE detection in 132.00…
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 8, 2026.
    60,128
    12,588
    5:24 PM
    add cmsec security check framework for kernel CVE detection in 132.00stable
    When enabled via DMOTD_CVECHECK='y' in /etc/centminmod/custom_config.inc,
    Centmin Mod servers now check at SSH login whether the running kernel is
    patched against known CVEs and surface a coloured status line in the
    message-of-the-day banner. Initial detection ships for CVE-2026-31431
    (algif_aead local privilege escalation, CVSS 7.8) covering AlmaLinux 8/9/10,
    Rocky 8/9/10, CloudLinux 7h/8/9/10, Oracle Linux 8/9/10, and Linode boot
    kernels. Stock CentOS 7 (3.10 kernel) reports NOT_AFFECTED for this
    specific CVE. Users can run cmsec from the shell for full per-CVE detail,
    cmsec list to enumerate available checks, and cmsec --json for monitoring
    integration. Default-off to match existing convention for security gates
    (SSHLOGIN_KERNELCHECK, NEEDRESTART_CHECK).
    This branch lacks inc/configfile_submenu.inc so the DMOTD_CVECHECK toggle
    is set manually in /etc/centminmod/custom_config.inc rather than via menu
    option 7. tools/cmm-security/ content is byte-identical with 141.00beta01
    and 140.00beta01.
    Changes:
    - New tools/cmm-security/ extensible framework: cmsec.sh dispatcher with
    subcommands run/list/check/probe and flags --json/--no-cache/--dmotd/
    --quiet/--probe/--yes; lib/cache.sh state-based cache invalidation
    keyed on uname -r + /etc/os-release ID:VERSION_ID + /proc/cmdline
    mitigation flag + kcarectl digest + check-script SHA + baseline SHA,
    with 24h TTL safety net, flock concurrency, atomic mv-based writes,
    and stale-cache fallback under contention; lib/osdetect.sh shared
    OS / kernel-track detection (Linode, EL8/9/10, EL7, container/chroot
    via /proc/1/root inode comparison)
    - New checks/check-cve-2026-31431.sh detection script (~981 lines,
    detection-only — probe code separated into its own file)
    - New probes/probe-cve-2026-31431.sh standalone AF_ALG bind probe with
    --yes guard, SOC/EDR warning banner, 5-second pause; never invoked by
    dmotd or cron paths
    - dmotd.sh: new cmsec_checks() function mirroring kernel_checks() pattern,
    gated on DMOTD_CVECHECK (default 'n'); push_dmotd_alerts() extended
    with cve branch using per-(CVE,kernel) cooldown markers under
    /var/cache/centminmod/cmsec/push/ to prevent Pushover spam on every
    SSH login (24h cooldown window); cooldown marker only created when
    curl exits 0 and Pushover API returns "status":1
    - check-for-updates.sh: parallel cmsec_checks() integration via
    push_update_alerts() for non-interactive paths
    - inc/cpcheck.inc: cmsec symlink at /usr/bin/cmsec with self-heal for
    dangling, wrong-target, and missing-symlink cases (readlink-based
    comparison against expected SCRIPT_DIR target)
    - command_shortcuts.txt: documents cmsec, cmsec list, cmsec check
    - Sunday=0 -> 7 fix in date +%u tests in dmotd.sh and check-for-updates.sh
    needs-restarting weekend gate (ISO 8601 returns 7 for Sunday; previous
    test-against-0 silently skipped Sunday)
    - Linode kernel handling: vulnerable verdicts on Linode-format kernels
    emit kernel-track-aware action text directing users to the Linode
    Cloud Manager rather than dnf upgrade alone (Linode-supplied kernel
    loads independently of the distro-managed kernel)
    - Container/chroot detection: cmsec --json emits a synthesised "skipped"
    document for non-derivable host-kernel verdicts so monitoring tools
    receive a JSON document for every check, never empty stdout
    - DMOTD_CVECHECK_SUPPRESS env var enables per-CVE suppression keyed on
    (CVE + running-kernel + verdict); user acknowledgement auto-clears
    when the kernel changes, forcing re-evaluation
    - BASELINE_VERIFIED_DATE staleness signal: warns when baseline data is
    older than 90 days; cmsec --json exposes baseline_age_days for
    monitoring tools
    132.00stable branch
