Fix Nginx dynamic module support with --with-compat flag in 123.09beta01 https://community.centminmod.com/threads/nginx-dynamic-modules-how-they-work.11189/#post-47781 Continue reading... 123.09beta01 branch Branch: GitHub - centminmod/centminmod at 123.09beta01 Commit History: Commits · centminmod/centminmod · GitHub
Nginx Dynamic Module Support Updates As per https://community.centminmod.com/threads/nginx-dynamic-modules-how-they-work.11189/ Should have working nginx dynamic module manual drop in of modules working with these 4 committed updates in 123.09beta01+ and newer versions https://community.centminmod.com/th...-with-with-compat-flag-in-123-09beta01.11191/ https://community.centminmod.com/th...-module-routine-update-in-123-09beta01.11192/ https://community.centminmod.com/th...c-module-setup-routine-in-123-09beta01.11193/ https://community.centminmod.com/th...n-variable-to-optional-override-nginx….11194/ So for manually dropped in nginx dynamic modules placed in /usr/local/nginx/modules, you can set in centmin mod persistent config file /etc/centminmod/custom_config.inc to NGXDYNAMIC_MANUALOVERRIDE='y' you can override centmin mod default behavior to purge manually dropped in nginx dynamic modules from /usr/local/nginx/modules and then add to /usr/local/nginx/conf/dynamic-modules-includes.conf the load_module line i.e. Code (Text): load_module "modules/ngx_pagespeed.so"; Then the Nginx dynamic module will persist even if it's control variable is set to = 'n' i.e. if NGINX_PAGESPEED='n' and NGXDYNAMIC_NGXPAGESPEED='n' is set.
