Beta Branch fix nginx IPv6 vhost auto detection in 130.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 28, 2023.
    7:05 AM
    - when optional Centmin Mod variables are enabled for VPS_IPSIX_CHECK_DISABLE='n' and VPS_IPSIX_CHECK_DISABLE_DEBUG='y', Nginx created vhosts will auto detect if server supports IPv6 and auto add Nginx IPv6 listen directives where appropriate. This update fixes when nv command line method is used to create Nginx vhost, the non-HTTPS vhost config is missing IPv6 listen directive https://community.centminmod.com/threads/invitation-to-test-native-nginx-ipv6-vhost-config-support-in-130-00beta01.23463/page-2#post-98274
    130.00beta01 branch
    Support Centmin Mod
