Beta Branch fix Nginx Clang compiler build routine in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 8, 2024.
    53,531
    12,134
    11:10 AM
    - fix optional Clang compiler builds for Nginx on EL8/EL9 when CLANG='y' is set in the persistent config file /etc/centminmod/custom_config.inc prior to centmin.sh menu option 4 nginx compile runs
    nginx -V
    nginx version: nginx/1.27.1 (080924-104818-almalinux9-kvm-95a2688)
    built by clang 17.0.6 (AlmaLinux OS Foundation 17.0.6-5.el9)
    built with OpenSSL 1.1.1 (compatible; AWS-LC 1.34.2) (running with AWS-LC
    1.34.2)
    140.00beta01 branch
