Beta Branch fix nginx 1.30.x and 1.31.x stream module and threads support in 140.…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Apr 16, 2026.
    60,128
    12,588
    4:40 PM
    fix nginx 1.30.x and 1.31.x stream module and threads support in 140.00beta01
    The stream module version whitelist in nginx_configure.inc only included
    versions up to 1.29, causing nginx 1.30.x builds to omit --with-stream
    and --with-threads configure flags. This resulted in compilation failures
    when stream-dependent modules (stream-lua, stream geoip, stream realip,
    stream ssl preread) were still added by separate code paths.
    Changes:
    - add nginx 1.30 and 1.31 to NGXUPGRADE_VER stream module whitelist
    - add nginx 1.30 and 1.31 to NGXINSTALL_VER stream module whitelist
    140.00beta01 branch
