Beta Branch fix maxminddb orphan repair audit to check the built so directly in 1…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 16, 2026 at 9:24 AM.
    59,514
    12,539
    5:42 PM
    fix maxminddb orphan repair audit to check the built so directly in 140.00beta01
    The post-repair audit used php_ext_so_missing, which requires
    maxminddb.ini to still exist - but a failed GeoIP2 extension rebuild
    removes the stale ini as part of its .so-gated ini write, so the
    warning could never fire on exactly the failure it was meant to report.
    Changes:
    - inc/php_upgrade.inc: audit the maxminddb.so presence in the PHP
    extension dir directly after the reinstall attempt instead of via
    php_ext_so_missing
    140.00beta01 branch
