Stable Branch fix fresh install abort when NGINX_LIBBROTLI or NGINX_ZSTD is enabled…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Nov 25, 2026 at 3:54 PM.
    60,620
    12,635
    8:50 PM
    fix fresh install abort when NGINX_LIBBROTLI or NGINX_ZSTD is enabled in 132.00stable
    Fresh installs with NGINX_LIBBROTLI='y' or NGINX_ZSTD='y' aborted before nginx
    was built: ngxbrotli_download and nginx_zstd_setup edit nginx.conf, which does
    not exist yet at that stage, so they returned 2 and the funct_nginxconfigure
    PIPESTATUS checks failed the install.
    Changes:
    - inc/brotli.inc: only edit nginx.conf in ngxbrotli_download when it exists
    - inc/zstd_nginx.inc: only edit nginx.conf in nginx_zstd_setup when it exists
    - inc/nginx_install.inc: add the brotli_inc.conf and zstd_inc.conf includes after
    the nginx.conf template is copied on initial installs, so NGINX_LIBBROTLI='y'
    and NGINX_ZSTD='y' turn on brotli and zstd compression
    132.00stable branch
