Master Branch allow manual forced Google Brotli dependency update for ngx_brotli in…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 31, 2018.
    12,577
    7:26 PM
    allow manual forced Google Brotli dependency update for ngx_brotli in 123.09beta01
    - ngx_brotli nginx module https://github.com/eustas/ngx_brotli is built against Google Brotli. However, Google Brotli version used can be outdated. This update allows experimental forced manual update for Google Brotli version for ngx_brotli via persistent config file /etc/centminmod/custom_config.inc set variable NGINX_BROTLIDEP_UPDATE='y' which is disabled by default to allow ngx_brotli to use the intended Google Brotli version. When enabled NGINX_BROTLIDEP_UPDATE='y' prior to centmin.sh menu option 4 nginx update/compiles, it will override the intended Google Brotli version and use latest version available https://github.com/google/brotli/releases. This is not the Google Brotli version intended by ngx_brotli developer/author so use with care and there maybe bugs unforseen.
