Stable Branch fix CSF pure-ftpd passive port range in 124.00stable
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 24, 2023.
    50,479
    11,664
    9:27 PM
    - fix csf v14.18 adding DoT DNS over TLS port 853 which broke Centmin Mod initial install CSF port list configuration and didn't add pure-ftpd passive port range to whitelist this update runs a fimcyopm on centmin.sh menu runs to check if pure-ftpd passive port range is missing and auto re-add it if script runs, there will be a backup of prior CSF Firewall profile config at /var/lib/csf/backup/ named fix-ftp from csf --profile backup fix-ftp command run
    - existing users can run cmupdate and then run and exit centmin.sh once
    124.00stable branch
