Stable Branch restore user-friendly cmupdate output in 132.00stable
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 20, 2026.
    60,143
    12,590
    4:08 AM
    Port of the 141.00beta01 fix. Same regression introduced by b27d155f
    (rebase-aware _cmm_git_sync_impl helper) — running cmupdate on an
    up-to-date checkout prints only bare "From <URL> -> FETCH_HEAD" lines.
    Additionally fixes a stray-backslash grep pattern that triggers
    "grep: warning: stray \ before /" on GNU grep 3.8+.
    Changes:
    - inc/git_sync.inc: emit status messages around fetch/merge:
    - "Checking for updates on origin/<branch> ..." before fetch
    - "Already up to date with origin/<branch> at <short_sha>." on the
    SHA-equal path (previously silent)
    - "Fast-forwarding <branch> to origin/<branch> ..." before merge
    - "Updated to <short_sha> <subject>." after successful FF
    - swap git pull --ff-only origin "$branch" ->
    git merge --ff-only "origin/$branch" to eliminate the duplicate
    "From <URL> -> FETCH_HEAD" line (we already fetched).
    - error string at line 74 updated to match the new command name.
    - tools/cmupdate.sh:
    - remove the bare fupdate call before the case "$1" block so
    every cmupdate invocation runs fupdate once instead of twice.
    Side benefit: cmupdate update-stable / update-beta no longer
    sync the current branch first before switching, and the cmsec
    symlink work in fupdate runs once instead of twice.
    - wrap the _cmm_git_sync call (CHECK_GITCLEAN=no path) with the
    same banner / git branch / git log -1 framing updatecm.sh uses;
    use git log -1 --pretty=tformat:'Latest commit: %h (%ad)%n %s'
    --date=short for a compact two-line summary that fits 80-col
    SSH terminals.
    - fix grep pattern 'HTTP\/' -> 'HTTP/' (the backslash before /
    is meaningless and triggers a grep warning on newer GNU grep).
    - inc/updater_submenu.inc: drop the two stale cecho hint lines that
    printed "git stash" / "git pull" as user instructions in
    gitenv_update. The actual work is done by _cmm_git_sync_impl.
    132.00stable branch
