Beta Branch fix cmupdate self-recovery from upstream rebase in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 20, 2026.
    60,143
    12,590
    3:54 AM
    cmupdate (and updatecm.sh cron, menu 23 submenu 2, AUTO_GITUPDATE=y
    startup) breaks with "fatal: Not possible to fast-forward, aborting."
    when 141.00beta01 / 140.00beta01 / 132.00stable is rebased on GitHub.
    All four callsites did the same fast-forward-only git stash; git pull.
    A new inc/git_sync.inc helper detects divergence via
    git merge-base --is-ancestor and routes:
    - fast-forward: stash with refs/stash sentinel, pull --ff-only, pop
    only the stash it created (never user's pre-existing stash)
    - local-ahead: warn and skip, never rewinds local commits
    - diverged (upstream rebase): tag HEAD as cmupdate-pre-resync-<epoch>,
    stash dirty WT, hard-reset to origin/<branch>. Refuses to reset if
    stash failed and working tree is dirty.
    After this lands, cmupdate self-recovers on every future rebase.
    A new tools/cmupdate-fix.sh one-shot script unsticks users already
    running a pre-fix cmupdate. Auto-detects local branch, translates
    common git errors to plain English, prints step status and a
    RESULT: SUCCESS|FAILED summary with rollback commands.
    curl -fsSLo /tmp/cmupdate-fix.sh \\
    https://raw.githubusercontent.com/centminmod/centminmod/140.00beta01/tools/cmupdate-fix.sh \\
    && bash /tmp/cmupdate-fix.sh
    EL7 git 1.8.3.1 compatible (git stash save -u; git merge-base
    --is-ancestor since git 1.8.0).
    Changes:
    - Add inc/git_sync.inc _cmm_git_sync_impl helper
    - Add tools/cmupdate-fix.sh recovery script
    - tools/cmupdate.sh: wrapper + panic-stub bootstrap; use helper at 86-89
    - updatecm.sh: wrapper + panic-stub; detached-HEAD-safe branch detect;
    emit grep-able cmupdate-status: branch=X rc=Y for cron mail
    - inc/updater_submenu.inc: source git_sync.inc in re_sourcefiles;
    use helper at 227-229
    - inc/cpcheck.inc: auto_gitupdate prefers helper; legacy fallback
    uses pull --ff-only so rebase failures become silent no-ops
    140.00beta01 branch
