Beta Branch fix cmsec python cwd import, JSON fallback, dnf updateinfo errors and…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Nov 28, 2026 at 6:34 PM.
    60,650
    12,635
    4:41 AM
    fix cmsec python cwd import, JSON fallback, dnf updateinfo errors and cache key races in 140.00beta01
    Five defects shared by every cmsec check. A root run from a directory
    holding a json.py imported it; the Python-free JSON fallback produced
    invalid JSON when a quote appeared after the first line; a failed dnf
    updateinfo query read as an update listing; and the cache could store a
    verdict under a key that no longer matched the host, or serve any stored
    verdict when the state key could not be computed.
    Changes:
    - tools/cmm-security/checks/*.sh (all 10 checks): json_escape() runs
    python3 -I (isolated mode), and its sed fallback joins all lines before
    escaping, so multi-line text with quotes stays valid JSON. The 8 checks
    that run dnf updateinfo print the dnf error and record a reason when the
    query fails.
    - tools/cmm-security/cmsec.sh: the same two fixes in
    cmsec_json_escape_inner(); run_check_fresh() rechecks the state key
    after the check runs and caches the result only when it is unchanged;
    an empty state key skips the cache.
    - tools/cmm-security/lib/cache.sh: cache reads, stale reads and writes
    refuse an empty state key.
    140.00beta01 branch
