Beta Branch make cmsec dnf updateinfo and kernel-update checks security-repo awar…
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 22, 2026.
    60,144
    12,590
    6:29 AM
    make cmsec dnf updateinfo and kernel-update checks security-repo aware on Rocky in 140.00beta01
    The CVE-updateinfo and available-kernel-update dnf queries used only the
    default-enabled repos, so on Rocky they never saw the opt-in `security` repo
    (enabled=0 by default) where the kernel re-spins live. A vulnerable or
    behind-on-the-respin Rocky host therefore saw "no updates available" even when
    the security repo carried a newer fix.
    Changes (four kernel-core checks; 43500 has no dnf-query sections):
    - Compute dnf_security_enable=--enablerepo=security only when os_id=rocky AND
    /etc/yum.repos.d/rocky-security.repo exists; empty everywhere else.
    - Thread it into `dnf updateinfo list --cve` and `dnf --refresh check-update
    kernel*` so both surface security-repo content without permanently enabling
    the repo. Print a one-line note when it is in effect.
    140.00beta01 branch
