Stable Branch add cmsec CVE-2026-43284 + CVE-2026-43500 dirtyfrag detection in 132.00stable
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 9, 2026.
    59,476
    12,536
    3:45 PM
    Two new cmsec check scripts ship the Dirty Frag (CVE-2026-43284 xfrm-ESP +
    CVE-2026-43500 RxRPC) verdict line in the dmotd SSH banner across CentOS 7,
    RHEL 7/8/9/10, AlmaLinux 8/9/10 (incl. Kitten), Rocky 8/9/10, Oracle Linux
    8/9/10 RHCK, and CloudLinux 7/7h/8/9/10. Discovery is automatic via the
    existing check-*.sh filename glob — no dispatcher or dmotd.sh changes
    required.
    On 132.00stable the runtime is EL7-aware. CVE-2026-43284 short-circuits to
    not_affected with confidence medium for stock CentOS 7, RHEL 7, and
    CloudLinux 7 (non-h), and to AFFECTED for CloudLinux 7h
    (kernel_track=cloudlinux-7h via osdetect.sh). CVE-2026-43500 short-circuits
    to not_affected on EL7 because the rxrpc kernel module is not built.
    Verdicts return almost instantly in the dmotd hot path on these hosts.
    CVE-2026-43284 (xfrm-ESP) verdict logic mirrors the 31431 template's
    case-statement on \${os_id}:\${os_version} but with these distinctions:
    - centos:7* + rhel:7* + cloudlinux:7 (non-h) → not_affected; the in-place
    ESP decrypt fast path was introduced upstream in commit cac2661c53f3
    (2017-01-17), postdating the EL7 3.10 codebase. Confidence medium pending
    RHSB-2026-003.
    - cloudlinux:7* with kernel_track=cloudlinux-7h → AFFECTED; CL7h hybrid
    kernel is based on EL8 (osdetect.sh:46 sets the track via *.lve.el7h*).
    - AL8/Rocky 8/RHEL 8 baseline kernel-4.18.0-553.123.2.el8_10
    - AL9/Rocky 9/RHEL 9 baseline kernel-5.14.0-611.54.3.el9_7
    - AL10/Rocky 10/RHEL 10/Kitten 10 baseline kernel-6.12.0-124.55.3.el10_1
    - CloudLinux 10: ESP-only floor 6.12.0-124.55.2.el10_1; raised to AL10
    6.12.0-124.55.3.el10_1 floor when rxrpc is present (CL .55.2 lacks the
    combined RxRPC fix as of 2026-05-08).
    - Oracle / CloudLinux / RHEL NVRs flagged pending_vendor_nvr=true; AlmaLinux
    baseline used as conservative floor until vendors publish.
    CVE-2026-43500 (RxRPC) is a slim variant: EL7 / EL8 / Linode / containers
    short-circuit to not_affected (rxrpc module never built/shipped). EL9/10
    (incl. RHEL 9/10) fall through to detect_rxrpc_presence(): /sys/module/
    rxrpc, modules.builtin, /lib/modules/*/{kernel,extra,partner}/net/rxrpc/
    rxrpc.ko*, modinfo, and rpm -q kernel-modules-partner-\$(uname -r) for
    AlmaLinux. When rxrpc is absent the verdict is not_affected; when present
    it's compared against the same vendor baseline used for 43284. Vendors
    other than AlmaLinux mark rxrpc_package_path_verified=false in JSON until
    packaging confirmed.
    The modprobe-blacklist stopgap (install esp4 /bin/false) is suppressed on
    hosts that appear to use IPsec — detected via ip xfrm policy/state list,
    strongswan/libreswan/ipsec service state, /etc/ipsec.{conf,d/*.conf,secrets},
    /etc/swanctl/**/*.conf, /etc/strongswan{.conf,.d}, NetworkManager VPN
    connections (nmcli type=vpn — NOT type=wireguard, since WireGuard is
    unaffected by xfrm-ESP), and /etc/NetworkManager/system-connections/
    *.nmconnection profiles with vpn-type=libreswan|strongswan|ipsec. Applying
    the workaround on those hosts breaks IPsec data-path traffic; the long-form
    output prints a hard red warning and recommends kernel update only.
    The detect_modprobe_blacklist() function intentionally tracks esp4/esp6
    only — a file blacklisting only rxrpc does NOT mark this CVE's mitigation
    as active, since rxrpc blacklist mitigates only CVE-2026-43500 (its own
    check owns that detection).
    Cache-key extension in lib/cache.sh appends a 7th tuple field to
    cmsec_cache_state_key — a SHA-256 over /etc/modprobe.d, /usr/lib/modprobe.d,
    and /run/modprobe.d files containing esp4|esp6|rxrpc blacklist directives,
    folded with /proc/modules state for the same modules. This invalidates the
    cached verdict the moment the user toggles /etc/modprobe.d/dirtyfrag.conf
    or rmmod's the modules. ALL existing /var/cache/centminmod/cmsec/*.cache
    entries (incl. cve-2026-31431) invalidate on first run after upgrade —
    by design.
    Changes:
    - tools/cmm-security/checks/check-cve-2026-43284.sh (NEW, ~860 lines)
    detection-only; no probe script. Flag matrix: --json --quiet --debug
    --log-file --help. Emits final_status \\u2208 {patched, not_affected,
    vulnerable, indeterminate} with snake_case JSON keys (esp4_state,
    esp6_state, rxrpc_state, modprobe_blacklist_path, ipsec_host_detected,
    ipsec_detection_reasons, pending_vendor_nvr, vendor_baseline,
    comparison_result, livepatch_*).
    - tools/cmm-security/checks/check-cve-2026-43500.sh (NEW, ~470 lines)
    same flag matrix; slim verdict path gated on rxrpc presence detection.
    - tools/cmm-security/lib/cache.sh — cmsec_cache_state_key digest tuple
    extended from 6 fields (kernel|os|cmdline|livepatch|script|baseline) to
    7 fields with the trailing modprobe_dirtyfrag_digest. printf goes from
    6 to 7 %s.
    - Cross-AI-reviewed (Codex GPT-5.5 + code-searcher); P0 fixes folded in:
    added stock RHEL 7/8/9/10 routing in 43284 and RHEL 9/10 routing in
    43500, removed wireguard from NetworkManager IPsec heuristic (WireGuard
    does NOT use xfrm-ESP), narrowed detect_modprobe_blacklist to esp4/esp6
    only (rxrpc-only blacklist is irrelevant to ESP CVE), deduped
    strongswan-installed marker.
    - Branch parity with 141.00beta01 (commit 70d5bb5f) and 140.00beta01
    (commit 20dd8cda); tools/cmm-security/ remains byte-identical across
    all three branches.
    132.00stable branch
