Beta Branch fix nginx logrotate su nginx nginx for domain log directories in 140.…
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 8, 2026.
    60,128
    12,588
    5:45 PM
    fix nginx logrotate su nginx nginx for domain log directories in 140.00beta01
    Domain log directories at /home/nginx/domains/*/log/ have mode 2770 with
    nginx:nginx ownership. logrotate silently skips these due to its security
    check for group-writable parent directories not owned by root
    Changes:
    - split single logrotate config block into two: root-owned dirs (no su)
    and domain dirs (with su nginx nginx)
    - update logrotate/nginx static template, inc/logrotate_nginx.inc
    funct_logrotate() 4 heredoc variants, and inc/cpcheck.inc fixlogrotate()
    4 heredoc variants with ZSTD detection and JSON log patterns
    - fix fixlogrotate() condition that previously removed su nginx when found
    to instead detect absence of su nginx nginx and add it
    - add fix_nginx_logrotate_domain_su() one-time cleanup function that
    detects servers with domain paths but missing su nginx nginx and triggers
    force-rotation of accumulated domain logs
    - update fix_nginx_logrotate_el9() to also trigger when existing systemd
    drop-in lacks ReadWritePaths for /home/nginx/domains
    - add ReadWritePaths=/home/nginx/domains to EL9/EL10 systemd drop-in for
    logrotate.service to handle ProtectHome=true
    140.00beta01 branch
