Beta Branch fix checkipvsix function for IPv6 check in CSF Firewall in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Nov 8, 2016.
    55,811
    12,273
    8:06 PM
    55,811
    12,273
    8:06 PM
    To deploy the fix which only affects 123.09beta01:
    1. use centmin.sh menu option 23 submenu option 2 to update
    2. then exit centmin.sh via menu option 23 and
    3. then change into /usr/local/src/centminmod directory again and run centmin.sh once and exit.
    OR use git command line equivalent in SSH as root user type
    cd /usr/local/src/centminmod
    git stash
    git pull
    ./centmin.sh
    This CSF Firewall related bug fix is for a recent update made yesterday at Beta Branch - add checkipvsix function to detect if IPv6 networking enabled so if you haven't ran centmin.sh shell menu in last 24 1/2 hrs, you would not have been affected by the bug. Only would be affected if you ran centmin.sh shell menu in the last 24 1/2 hrs.
