Install Nginx First Install - Xenforo running - but got some questions
Discussion in 'Install & Upgrades or Pre-Install Questions' started by hazehs, Jul 27, 2020.
  1. hazehs
    hazehs New Member
    25
    8:54 AM
    NGINX 1.18
    MariaDB 10.4
    • CentOS Version: i.e. CentOS 6 32bit or 64bit / CentOS 7 64bit ?
    • Nginx Version Installed: 1.19.1
    • PHP Version Installed: 7.3.x
    • MariaDB MySQL Version Installed: 10.2.xx
    • When was last time updated Centmin Mod code base ? :
      ZSTD_LOGROTATE_NGINX='y'
      ZSTD_LOGROTATE_PHPFPM='y'
      PHP_PGO='y'
      PHP_LZFOUR='y'
      PHP_LZF='y'
      PHP_ZSTD='y'
      DUALCERTS='y'
      LETSENCRYPT_DETECT='y'
      # Cloudflare DNS API for DNS Mode
      # https://github.com/Neilpang/acme.sh/tree/master/dnsapi
      # login to your Cloudflare account to get your API Key in
      # My Settings section of your account
      # to ensure these settings persist DO NOT change them in this
      # script but set these variables in persistent config file at
      # /etc/centminmod/acmetoool-config.ini
      # set to CF_DNSAPI='y' and fill in CF_KEY and CF_EMAIL settings
      CF_DNSAPI='y'
      CF_KEY=''
      CF_EMAIL=''
      AUDITD_ENABLE='y'
    So. First of all thanks for the stack. I was long time affraid off it, cause there are so many informations, but so far it is working good. My problem was that i cant do http01 challenge cause the dns is not pointing on my ip.
    So first off all:
    Is it possible to disable the main host? Im afraid about leaking my ip through the hostname.
    Second: Caching for Xenforo: I got still a small forum but it is growing. 120-150 Member. Should i stay for Redis or Memcached ?
    Last one: Firewall: Im only using the 443/80 Port for Web at outgoing service. And i need to only allow to access my Reverse proxys provider ip (ip, proxy ip).
    SSH i would open for my static IP. I dont understand CSF so far..
    Thanks for Help and Regards!
    45,183
    10,276
    6:54 PM
    http-01 challenge is web root authentication it validates based on a generated file at yourdomain.com/.well-known/* So the only requirement DNS wise is you're pointing your www and non-www domain DNS A ipv4 and if applicable DNS AAAA ipv6 IP addresses to Centmin Mod server IP and if you're behind Cloudflare that should still work as validation is looking for yourdomain.com/.well-known/* generated file and you should be able to get to that.
    Make sure you have not used main hostname domain as your xenforo domain, they need to be separate as per Getting Started Guide step 1 and 2 Getting Started Guide - CentminMod.com LEMP Nginx web stack for CentOS
    From the Getting Started Guide summary
    So you want to install xenfor on the newdomain.com and not main hostname.newdomain.com you setup in step 1.
    Redis is better
    You can read up on how to whitelist an IP address at CSF Firewall - CentminMod.com LEMP Nginx web stack for CentOS
    45,183
    10,276
    6:54 PM
