Authorization not available. Check if polkit service is running
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Jun 28, 2019.
    4,128
    4:37 AM
    • Nginx Version Installed: 1.15.12
    • PHP Version Installed: 7.3.x
    • MariaDB MySQL Version Installed: 10.2.xx
    • When was last time updated Centmin Mod code base ? : a week ago
    Hello
    Today without adjusting anything i tried to run nprestart on a dedicated server Centos 7 and i got this error:
    IF i wait for a few seconds i am getting also this:
    I can't run any command even reboot....
    Checking on the net it seems that many have that issue without a solution...
    If anyone can help please....
    Thank you
  2. pamamolf
    4,128
    4:37 AM
    Ok it works now after a hard reboot....
    60,086
    12,584
    12:37 PM
    did you do some yum updates which had linux kernel etc but didn't do a reboot before ?
  4. pamamolf
    4,128
    4:37 AM
    Yes but i did the same on the rest of my servers but they didn't had that issue....
    60,086
    12,584
    12:37 PM
    it can be an accumulation of multiple delayed/required reboots that builds up after successive yum updates which usually require a reboot
