Xenforo Fastcgi cache configuration for Xenforo?
Discussion in 'Forum software usage' started by Everlind, Jun 17, 2014.
    12:26 AM
    He didn't implemented it here :(
    2:26 AM
    Yeah not running fastcgi_cache on this forum :)
  3. hungphutho
    hungphutho Member
    55
    35
    11:26 PM
    1.7.2
    Percona 5.6
    add xf_style_id=xx|xf_style_id=xx
    # Don't use the cache for logged in users and Don't use the cache for guest change style
        if ($http_cookie ~* "xf_session_admin|xf_user|xf_user_admin|xf_style_id=xx|xf_style_id=xx") {
            set $no_cache 1;
  4. rdan
    12:26 AM
    I don't really know what Floren mean here :(
    Nginx Fastcgi_cache configuration for Xenforo Board | XenForo Community
  5. rdan
    12:26 AM
    @hungphutho
    I have this problem now:
    What is your solution for this issue?
  6. Floren
    Floren Active Member
    148
    77
    12:26 PM
    @RoldanLT has a tendency to ask things on 200 forums, except AXIVO. :D
    I told him exactly what to do, but instead of following my advice, he posts things all over the places "hoping" it will work.
  7. hungphutho
    hungphutho Member
    55
    35
    11:26 PM
    1.7.2
    Percona 5.6
  8. rdan
    12:26 AM
  9. pamamolf
    4,128
    7:26 PM
    Is it possible to use fast cgi cache path to a tmpfs partition without doing the trick for guests ?
    And it will really help or it is only for the trick with the guests?
    2:26 AM
    what do you mean tricks for guests ? fastcgi_cache is predominantly only used for caching for guests never logged in users - same goes for wordpress and fastcgi_cache - guests only
  11. pamamolf
    4,128
    7:26 PM
    It works only if you do the cookie trick for guests or it works in general for guests without any cookie settings?
    2:26 AM
    Every web/php app will need some form of cookie manipulation and/or understanding of that web/php app's cookie/session functionality to properly implement fastcgi_cache for nginx/php-fpm. It's one reason I can implememt fastcgi_cache for wordpress and just a bit off and not able to for xenforo as I know wordpress well and xenforo not as well. Hence, why fastcgi_cache is left to end users to do as it requires an understanding of the web/php app itself to properly implement. It's same for Varnish Cache too, understanding the web/php app is important - especially for how the web/php app deals and uses cookies/sessions for guests and non-guests.
  13. nfn
    nfn New Member
    29
    5:26 PM
    I just register here today.
    I came from IPB, just mover last weekend to XF and I'm loving this :)
    in IPB I use this same technic to cache pages for guest, but with xf I don't see xf_user or xf_user_admin in my headers,
    Do theses cookies still exists in XF1.4?
    I only see xf_session_admin and xf_session
  14. rdan
    12:26 AM
    Stay logged in, must be checked always and hidden so that xf_user cookies will be available.
  15. rdan
    12:26 AM
  16. rdan
    12:26 AM
    2:26 AM
  18. negative
    negative Active Member
    415
    50
    7:26 PM
    1.9.10
    10.1.11
    @rdan @eva2000
    How can we exclude the forum homepage or set different cache time ?
    2:26 AM
    If you're not familar with fastcgi_cache, I would use a different caching method as fastcgi_cache is left to end user to customise. Though excluding home page location context / is difficult as is due to location match.
    As to changing time it's in fastcgi_cache_valid Module ngx_http_fastcgi_module
  20. negative
    415
    50
    7:26 PM
    1.9.10
    10.1.11
    One way is exclude the homepage i though but i didn't
    Actually, my forum installed on /forum/ directory and i've tried the exclude /forum/, /forum or like /forum/index.php but it didn't, it exludes all forum and sub pages.
    What are u using on that forum @eva2000 ? Only nginx pagespeed or what?
