Nginx fancyindex nginx module customisation
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by BobbyWibowo, Jun 19, 2016.
  1. BobbyWibowo
    BobbyWibowo Active Member
    197
    42
    Indonesia
    9:52 AM
    1.17.x
    10.3.x
    @eva2000 By the way, I installed this fancyindex theme: GitHub - TheInsomniac/Nginx-Fancyindex-Theme: Theme for Nginx' fancyindex module and it's working properly. But it recommended that I change NGX_HTTP_FANCYINDEX_NAME_LEN of ngx_http_fancyindex_module.c from 50 to 500 (or any other number greater than 50). How do you suppose I do that change automatically on every nginx rebuild?
    55,896
    12,281
    12:52 PM
    I also use same theme too for fancyindex :D
    in fancyindex 0.4.0 module there is no such variable found via grep at least
    grep 'NGX_HTTP_FANCYINDEX_NAME_LEN' /svr-setup/ngx-fancyindex-0.4.0/ngx_http_fancyindex_module.c
    because there's now an nginx variable to control size
  3. BobbyWibowo
    197
    42
    Indonesia
    9:52 AM
    1.17.x
    10.3.x
    Ah, what a coincidence :D
    And thanks, the following works properly :)
    location ^~ /path/to/deluge/downloads {
      alias /var/lib/deluge/Downloads;
      include /usr/local/nginx/conf/fancyindex.conf;
      fancyindex_name_length 500;
    Though I suppose it'd have been somewhat better to edit the fancyindex.conf instead, but ehh, at least it works :D
