Nginx SSL Facing Issue With Conflicting SSL When Using Option 22
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by skringjer, Sep 27, 2022.
  1. skringjer
    skringjer NoobMaster69
    208
    26
    10:15 PM
    Nginx 1.21.6
    • Nginx Version Installed: 1.21.6
    • PHP Version Installed: 7.4.27
    • MariaDB MySQL Version Installed: 10.3.36-MariaDB
    • When was last time updated Centmin Mod code base ? : Auto Cron Updates
      NGINX_STAPLE_CACHE_OVERRIDE='y'
      NGINX_STAPLE_CACHE_TTL='86400'
      AUTOHARDTUNE_NGINXBACKLOG='y'
      ZSTD_LOGROTATE_NGINX='y'
      ZSTD_LOGROTATE_PHPFPM='y'
      LETSENCRYPT_DETECT='y'
      DUALCERTS='y'
      SELFSIGNEDSSL_ECDSA='y'
      NGINX_LIBBROTLI='y'
      NGXDYNAMIC_BROTLI='y'
      PHP_PGO_ALWAYS='y'
      PHP_PGO='y'
      PHP_BROTLI='y'
      PHP_LZFOUR='y'
      PHP_LZF='y'
      PHP_ZSTD='y'
      PHPFINFO='y'
      WPCLI_CE_QUERYSTRING_INCLUDED='y'
      NGINX_GEOIPTWOLITE='y'
      NGXDYNAMIC_GEOIPTWOLITE='y'
      MM_LICENSE_KEY='TnmH7f3jjS0axmsT'
      AUDITD_ENABLE='y'
      NGINX_PAGESPEED='y'
      NGXDYNAMIC_NGXPAGESPEED='y'
    Greetings everyone, i am facing issue with a new Option 22 wordpress vhost, Everything goes fine, the SSL is issued, but when i test the SSL i get an error
    A valid Root CA Certificate could not be located, the certificate will likely display browser warnings.
    And then when i tested it on SSLLAB, i got an error on 2nd Certificate, which shows another one of my vhost domain.
    Alternative names myotherdomain.com www.myotherdomain.com MISMATCH
    i tried force reissue but that dosent fix the issue.
    54,583
    12,224
    3:15 AM
    First try running your intended SSL certificate domain through the letsdebug.net online testing tool to check for potential errors with HTTP-01 validation. If you created Centmin Mod 123.09beta01 or higher Nginx site with Letsencrypt via centmin.sh menu option 2, 22 or nv command line, you now also have an automatic letsdebug.net API check log saved at /root/centminlogs/letsdebug-yourdomain.com-${DT}.log where yourdomain.com is domain specified during nginx vhost creation and DT is date/timestamp. Inspecting the /root/centminlogs/letsdebug-yourdomain.com-${DT}.log log will also give you clues as to why letsencrypt SSL certificate issuance failed.
    How was the initial letsencrypt ssl certificate obtained ? Which method ?
    • Was the domain nginx vhost alreadying created prior or new domain nginx vhost site setup for first time ?
    • Via centmin.sh menu option 2, 22, /usr/bin/nv ?
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Setup full Nginx vhost + Wordpress + WP Plugins
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    • Via addons/acmetool.sh ? which specific command ? examples
      ./acmetool.sh issue acme.domain.com
      ./acmetool.sh issue acme.domain.com live
      ./acmetool.sh issue acme.domain.com d
      ./acmetool.sh issue acme.domain.com lived
    • What was order of steps you did ? Did you run centmin.sh menu option 2 first with letsencrypt ? Then did you run addons/acmetool.sh afterwards ?
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
    echo | openssl s_client -connect yourdomain.com:443
    SSLLabs Test
    Also run your HTTPS domain site through SSLLabs tester at SSL Server Test (Powered by Qualys SSL Labs) if it says untrusted SSL cert and prompts to continue the test, continue the test.
    Cloudflare
    If you use Cloudflare, instead of the default Letsencrypt web root validation, you can use Cloudflare's DNS API for Letsencrypt DNS validation for your domain. See the outline at bottom of page at Letsencrypt Free SSL Certificates
