Error while running centmin.sh command
Discussion in 'Install & Upgrades or Pre-Install Questions' started by drabhaydaga, Jun 30, 2021.
  1. drabhaydaga
    drabhaydaga New Member
    7:02 PM
    • Nginx Version Installed: 1.19.7
    • PHP Version Installed: 7.4.15
    • MariaDB MySQL Version Installed: 10.2.xx
    • When was last time updated Centmin Mod code base ? : 30/06/2021
      Post output in CODE tags.
      MARCH_TARGETNATIVE='n'
      LETSENCRYPT_DETECT='y'
      PHPFINFO='y'
      i am trying to shift my droplet of DO
      i took snapshot of current droplet and shifted
      but when i was trying to login via putty it was showing connection time out i tried with all isp so i thought there must me some error in original droplet so i tried to login the original one i shown following error when running centmin.sh command
      /usr/local/src/centminmod ~
      inc/nginx_configure.inc: line 3801: syntax error near unexpected token `}'
      inc/nginx_configure.inc: line 3801: `}'
      inc/cpcheck.inc: line 175: [: missing `]'
      also when trying to upgrade nginx to 1.21.0 getting following error
      inc/nginx_upgrade.inc: line 691: funct_nginxconfigure: command not found
      Wed Jun 30 08:03:23 UTC 2021
      Error: 127, Nginx configure failed
      report errors on the forums at community.centminmod.com/forums/8/
      with info asked at community.centminmod.com/threads/17778/
      and when running nginx -t
      nginx: [warn] the "http2_max_requests" directive is obsolete, use the "keepalive_requests" directive instead in /usr/local/nginx/conf/conf.d/shipping.spinefitmedical.com.ssl.conf:22
      nginx: [warn] the "http2_max_field_size" directive is obsolete, use the "large_client_header_buffers" directive instead in /usr/local/nginx/conf/conf.d/spinefitkorea.com.ssl.conf:20
      nginx: [warn] the "http2_max_header_size" directive is obsolete, use the "large_client_header_buffers" directive instead in /usr/local/nginx/conf/conf.d/spinefitkorea.com.ssl.conf:21
      nginx: [warn] the "http2_max_requests" directive is obsolete, use the "keepalive_requests" directive instead in /usr/local/nginx/conf/conf.d/spinefitkorea.com.ssl.conf:22
      nginx: [warn] the "http2_max_field_size" directive is obsolete, use the "large_client_header_buffers" directive instead in /usr/local/nginx/conf/conf.d/spinefitmedical.com.ssl.conf:20
      nginx: [warn] the "http2_max_header_size" directive is obsolete, use the "large_client_header_buffers" directive instead in /usr/local/nginx/conf/conf.d/spinefitmedical.com.ssl.conf:21
      nginx: [warn] the "http2_max_requests" directive is obsolete, use the "keepalive_requests" directive instead in /usr/local/nginx/conf/conf.d/spinefitmedical.com.ssl.conf:22
    plz let me know where i am wrong ??
    55,797
    12,271
    11:32 PM
    what is output from command for both servers
    cmupdate
    could be you snapshotted a bugged old server Centmin Mod Nginx config and brought it over to the new server. So ideally you fix the old server before you do the snapshot/transfer.
    55,797
    12,271
    11:32 PM
    For old server, what version are you on for Centmin Mod as inc/nginx_configure.inc in Centmin Mod 123.09beta01 latest code only has 3712 from lines centminmod/centminmod
    On old server run cmupdate and run centmin.sh menu once and exit to apply the updates and see if centmin.sh subsequent runs have issues
  4. drabhaydaga
    7:02 PM
    i am using 123.09beta01
    i run cmupdate
    cmupdate
    No local changes to save
    Already up-to-date.
    and run centmin.sh
  5. drabhaydaga
    7:02 PM
    i did clean Centmin Mod code replacement using below SSH commands
    branchname=123.09beta01
    cd /usr/local/src
    rm -rf centminmod*
    cd centminmod
    ./centmin.sh
    now it seams error has been resolved
    but why i am not able to access via ssh via putty ??
    i am jst able to access via internal console of digital ocean seams to be some error ?? or dont knw what i am doing wrong ??
    i have already shifted 3 droplets bt this specific 1 droplet is having issues
  6. drabhaydaga
    7:02 PM
    55,797
    12,271
    11:32 PM
    maybe your VPS network connectivity or local DNS resolver isn't working?
    what do you get for these commands
    dig +short A github.com
    ping -c4 github.com
    cat /etc/resolv.conf
    55,797
    12,271
    11:32 PM
    also check status of CSF Firewall and LFD daemon and post output for these commands
    service csf status | sed -e "s|$(hostname)|hostname|g"
    service lfd status | sed -e "s|$(hostname)|hostname|g"
    for posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags :)
  9. drabhaydaga
    7:02 PM
  10. drabhaydaga
    7:02 PM
    55,797
    12,271
    11:32 PM
    Your ping and dig commands return no service/errors suggest dns resolver issues. You can try rebooting the server to see if that fits VPS level issues if the DNS resolvers in /etc/resolv.conf are meant to be correct or also try adding
    nameserver 8.8.8.8
    and retry the ping and dig commands
    Instead of image screenshots for output, for posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags
