Error parsing header X-XSS-Protection: 1; mode=block;
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Jan 26, 2018.
    3,207
    305
    1:02 PM
    Nginx-1.13.x
    MariaDB 10.1.x
    • CentOS Version:CentOS 7 64bit ?
    • Nginx Version Installed: 1.13.8
    • PHP Version Installed: 7.1.x
    • MariaDB MySQL Version Installed: 10.1.30
    Hello :)
    I just notice this error at Chrome inspect tool:
    Searching on the net i found that it has to do with the headers and it can be fixed also in Nginx level ....
    What's your opinion and what's do you think will be the proper fix for this?
    Does Centminmod has any related setting at Nginx level to adjust?
    That's what i can see as related bt don't know if i must enable any of them or all or none :
    Maybe to enable that one?
    Thank you
    38,609
    8,527
    9:02 PM
  3. pamamolf
    3,207
    305
    1:02 PM
    Nginx-1.13.x
    MariaDB 10.1.x
    If anyone has any idea :)
    38,609
    8,527
    9:02 PM
    will you duplicate sets of x-xss-protection headers so that isn't the issue. Did you check with cloudflare bypass/disabled ?
  5. pamamolf
    3,207
    305
    1:02 PM
    Nginx-1.13.x
    MariaDB 10.1.x
    I will check it.....
