Nginx I get error when i start service varnish
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by congthanh, Apr 20, 2019.
  1. congthanh
    congthanh New Member
    3:09 AM
    1.13
    • CentOS Version: Centos 7 64Bit
    • Centmin Mod Version Installed: 123.08stable
    • Nginx Version Installed: nginx/1.15.2
    • PHP Version Installed: PHP 5.6.38 (cli)
    • MariaDB MySQL Version Installed: 10.0.36-MariaDB
    59,369
    12,513
    6:09 AM
    how old is the 123.08stable install ? nginx spdy was deprecated years ago for nginx http/2
    what is output for
    nginx -V
    post output in CODE tags
    make sure you update 123.08stable and recompile nginx
    Getting Started Guide step 19 outlines also how to keep Centmin Mod code updated or how to switch version branches or you can run cmupdate command that was recently added.
    Centmin Mod LEMP stack's script code is constantly updated for improvements, bug fixes and security fixes so keeping the Centmin Mod code up to date is important. With Centmin Mod 1.2.3-eva2000.08) (123.08stable) and higher releases, a newly added centmin.sh menu option 23 allows much easier code updates and version branch switching via Git backed environment you can setup.
    For 123.08stable that means centmin.sh menu option 23 submenu option 2 (if you previously ran submenu option 1) first, then exit centmin.sh, re-enter /usr/local/src/centminmod and re-run centmin.sh menu.
    For 123.09beta01 and higher that means running SSH command = cmupdate and then re-enter /usr/local/src/centminmod and re-run centmin.sh menu.
    Example of using 123.09beta01 cmupdate command to update Centmin Mod code on your server
    cmupdate
    No local changes to save
    Updating 5f92047..9d06ee8
    Fast-forward
     stackscripts/stackscript.sh | 11 ++++++++---
     1 file changed, 8 insertions(+), 3 deletions(-)
    For full details read the following links:
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to. You can easily update within a Centmin Mod version branch or switch version branches via centmin.sh menu option 23 outlined here.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at How to upgrade Centmin Mod software installed on your server.
  3. congthanh
    3:09 AM
    1.13
    Dear sir,
    i just update nginx and get error
    then i check nginx -t and get
    Thank you
    59,369
    12,513
    6:09 AM
    To troubleshoot, you need to check the full nginx upgrade log at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the nginx_upgrade.log log. You can see full details at How to troubleshoot Centmin Mod initial install issues
    also what's output of
    nginx -t
    when you run centmin.sh menu option 4 there's a nginx upgrade log timestamped at /root/centminlogs
    if you type this command it lists all logs in date ascending order so latest log at bottom
    ls -lArt /root/centminlogs
    so copy the entire contents of latest nginx_upgrade log to gist.github.com or pastebin.com
    you can use grep to filter the logs, i.e. look for nginx_upgrade in log name
    ls -lahrt /root/centminlogs/ | grep nginx_upgrade
    -rw-r--r--  1 root root 3.2M Oct 11 15:55 centminmod_1.2.3-eva2000.09.001_111016-155345_nginx_upgrade.log
    -rw-r--r--  1 root root 672K Oct 11 22:06 centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    So the last nginx upgrade log was named centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log and located at /root/centminlogs/centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    then use cat command to output the contents of that log
    cat /root/centminlogs/centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    then select and copy and paste output to pastebin.com or gist.github.com file to share. If your SSH client's scroll buffer isn't large enough using cat might not output the entire log file contents, so you may need to download the log and use local text editor to open and copy and paste.
    so only need content of one specific log, in this case most recent nginx_upgrade.log log
  5. congthanh
    3:09 AM
    1.13
    Dear Sir,
    My nginx_upgrade https://paste.ofcode.org/cS8Kuvr78VVFdz94EdyKuY
    Nginx -t
    Thank you
    59,369
    12,513
    6:09 AM
    the link isn't fully loading for me unfortunately - try pasetbin.com or gist.github.com
  7. congthanh
    3:09 AM
    1.13
    nginx update centminmod
    59,369
    12,513
    6:09 AM
    in /usr/local/nginx/conf/conf.d/nhaxinhmytho.com.ssl.conf comment out these 2 options with hash in front
    #spdy_headers_comp 5;
  9. congthanh
    3:09 AM
    1.13
    Dear Sir,
    I disable before.
    59,369
    12,513
    6:09 AM
    the nginx upgrade log says it's enabled
  11. congthanh
    3:09 AM
    1.13
    Dear Sir,
    But still now i disable 2 options.
    When i nprestart i get
    When i nginx -t
    Thank you
    59,369
    12,513
    6:09 AM
    output for
    ngxrestart; sleep 5; journalctl -xe -u nginx --no-pager | tail -100 | sed -e "s|$(hostname -f)|hostname|g" -e "s|$(hostname -s)|hostname|g"
  13. congthanh
    3:09 AM
    1.13
    Dear sir,
    Output
    59,369
    12,513
    6:09 AM
    you already have a service i.e. varnish server running on port 80 conflicting with nginx trying to start up on port 80 - so problem is nothing to do with centmin mod but your configuration of varnish cache server and improperly configuring nginx listen port to a port other than 80 - which is already occupied by varnish cache server
  15. congthanh
    3:09 AM
    1.13
    Dear sir,
    I try to change port nginx to 8080 in "virtual.conf"
    then i nprestart and check port of nginx
    Port 80 is listening
    How can i change nginx to 8080
    Thank you
    59,369
    12,513
    6:09 AM
    check that all nginx nginx's listen directives are no using 80 using command below to list nginx vhost files with listen port 80 referenced
    grep -rin 'listen' /usr/local/nginx/conf/conf.d/  | grep -v '#' | grep ' 80 '
    and check any listen directives which are not referencing a port other than 443, 8080 and 80 as blank listener default to port 80
    grep -rin 'listen' /usr/local/nginx/conf/conf.d/  | grep -v '#' | egrep -v ' 8080 | 80 | 443 '
  17. congthanh
    3:09 AM
    1.13
  18. congthanh
    3:09 AM
    1.13
    I
    it's empty
    then i
    But 2 nginx is running, a use port 80, use port 8080
    59,369
    12,513
    6:09 AM
    checked /usr/local/nginx/conf/conf.d/demodomain.com.conf ?
    59,369
    12,513
    6:09 AM
    ok to find and list all nginx vhosts which do not have a listen directive, use this SSH command
    find /usr/local/nginx/conf/conf.d/ -type f -not -exec grep -H -E -o -c  "listen"  {} \; | grep :0\$ | sed -e 's/..$//'
    example output reports that /usr/local/nginx/conf/conf.d/test.com.conf nginx vhost doesn't have a listen directive which in case that server_name will default to nginx port 80 usage. So if you need to change all nginx vhosts to port other than 80, you need to add the listen directive into that nginx vhost i.e. test.com.conf reported as not having one.
    so if test.com.conf has blank listen directive it defaults to port 80
                server_name test.com;
    so if you need to change to port 8080, you'd specifically set a listen directive
    change to
                listen   8080;
