SSL Letsencrypt Cloudflare ERR_TOO_MANY_REDIRECTS error after applying cloudflare SSL
Discussion in 'Domains, DNS, Email & SSL Certificates' started by pheonis, Feb 9, 2020.
  1. pheonis
    pheonis Member
    62
    9:55 AM
    Last day I added vhost and WordPress using the 22 option. After adding the domain. It was opening fine.
    Then I applied, Http and non-www redirect to https and www version. My domain.com.ssl.conf value:
    PHP:
     server {
    server_name domain.com;
        return
    302 https://www.domain.com$request_uri;
    server {
    listen 443 ssl http2;
      return
    ssl_dhparam /usr/local/nginx/conf/ssl/domain.com/dhparam.pem;
    ssl_certificate      /usr/local/nginx/conf/ssl/domain.com/domain.com.crt;
    ssl_certificate_key  /usr/local/nginx/conf/ssl/domain.com/domain.com.key;
      include /
    usr/local/nginx/conf/ssl_include.conf;
    server {
    server_name www.domain.com;
      include /
    Added Cloudflare line in the domain.com.ssl.conf
    Then set my Cloudflare SSL to "Full" in my Cloudflare dashboard.
    Now I am getting "ERR_TOO_MANY_REDIRECTS" error when I try to open my website in incognito mode.
    My Curl outputs:
    curl -I http://domain.com
    HTTP/1.1 302 Moved Temporarily
    Date: Sun, 09 Feb 2020 08:46:52 GMT
    Content-Type: text/html
    Connection: keep-alive
    Set-Cookie: __cfduid=db57d00760cc548ad9c85f29336c4ea8c1581238012; expires=Tue, 10-Mar-20 08:46:52 GMT; path=/; domain=.domain.com; HttpOnly; SameSite=Lax
    X-Powered-By: centminmod
    CF-Cache-Status: DYNAMIC
    Server: cloudflare
    CF-RAY: 56249348cd0be7ad-LAX
    curl -I https://domain.com
    Date: Sun, 09 Feb 2020 08:50:23 GMT
    Set-Cookie: __cfduid=d3e6c453e272fcd749bbbc67dcc2b808a1581238223; expires=Tue, 10-Mar-20 08:50:23 GMT; path=/; domain=.domain.com; HttpOnly; SameSite=Lax
    Server: cloudflare
    CF-RAY: 562498701c30eabb-LAX
    Date: Sun, 09 Feb 2020 08:53:44 GMT
    Set-Cookie: __cfduid=d9750fda5d2913643304046b3cbe8ab311581238423; expires=Tue, 10-Mar-20 08:53:43 GMT; path=/; domain=.domain.com; HttpOnly; SameSite=Lax
    X-Redirect-By: WordPress
    X-Page-Speed: 1.13.35.2-0
    Cache-Control: max-age=0, no-cache
    Server: cloudflare
    CF-RAY: 56249d54bc1598ff-LAX
    curl -I http://www.domain.com
    HTTP/1.1 200 OK
    Date: Sun, 09 Feb 2020 08:57:13 GMT
    Set-Cookie: __cfduid=d40f72a4a37b518e6e3f9a3a23f0949b91581238633; expires=Tue, 10-Mar-20 08:57:13 GMT; path=/; domain=.domain.com; HttpOnly; SameSite=Lax
    Vary: Accept-Encoding
    Server: cloudflare
    CF-RAY: 5624a2765c4fe7d9-LAX
    55,245
    12,253
    2:25 PM
    if you set non-https to https redirect on nginx level, disable HTTPS redirect/always use HTTPS in cloudflare dashboard or choose one method but not both
  3. pheonis
    pheonis Member
    62
    9:55 AM
    I have set my SSL mode to Full(Encrypts end-to-end, using a self signed certificate on the server) in Cloudflare. As you pointed outHTTPS redirect/always use HTTPS. It's disabled. Still facing the issue.
  4. pheonis
    pheonis Member
    62
    9:55 AM
    If i set the SSL mode to "Flexible(Encrypts traffic between the browser and Cloudflare)". Then My website opens with the Centmin page, not the bydefault Wordpress page.
