Letsencrypt Enabling Let's Encrypt for pure-ftp
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Cryptso, Dec 3, 2018.
  1. Cryptso
    Cryptso New Member
    9:01 AM
    Hello,
    Is there any way to deploy Let's Encrypt for pure-ftp and hostname?
    acmetool.sh is not allowing to get cert for hostname domain
    45,406
    10,302
    5:01 PM
    Unfortunately, right now there's no support for letsencrypt SSL certs with Pure-ftpd yet. The self-signed SSL is only one in use for Pure-ftpd
  3. Cryptso
    Cryptso New Member
    9:01 AM
    Ohh, its not good for me. Currently i'm developing in laravel framework and Sublime/VSC is giving connection error(due to self-signed cert). Is there any way to install dedicated SSL for hostname and pure-ftpd?
    45,406
    10,302
    5:01 PM
    Didn't know Sublime could do ftp ? No way to whitelist approve SSL cert in the apps like SFTP clients can ? There's manual way to install SSL for hostname but not for pure-ftpd. Though I guess if you get SSL for hostname, you could technically use it for pure-ftpd eventually. Below is for main hostname HTTPS SSL only.
    The only thing that can mess up virtual.conf main host is if you install phpmyadmin.sh addon. Otherwise, you can manually setup main hostname outlined in Getting Started Guide step 1 with HTTPS using vhost generator at Generate Centmin Mod Nginx Vhost - CentminMod.com LEMP Nginx web stack for CentOS
    type on domain fieldin main host name domain which has to have valid DNS A record pointing to server ip i.e. host.domain.com and check box that says Generate Self-Signed SSL / Letsencrypt SSL HTTPS Vhost (File ONLY) *
    Vhost type = basic and hit submit
    follow first 3 acme.sh commands only to get letsencrypt ssl cert but edit web root from
    /home/nginx/domains/host.domain.com/public to point to /usr/local/nginx/html and remove www. domain from -d
    enable letsencrypt in 123.09beta01 - 3 commands
    touch /etc/centminmod/custom_config.inc
    echo "LETSENCRYPT_DETECT='y'" >> /etc/centminmod/custom_config.inc
    /usr/local/src/centminmod/addons/acmetool.sh acmeupdate
    get letsencrypt ssl cert - 1 line cmd - webroot defined by -w /usr/local/nginx/html
    /root/.acme.sh/acme.sh --force --issue --days 60 -d host.domain.com -w /usr/local/nginx/html -k 2048 --useragent centminmod-centos-acmesh-webroot --log /root/centminlogs/acmetool.sh-debug-log-host.domain.com.log --log-level 2
    install letsencrypt ssl cert - 2 line cmds
    mkdir -p /usr/local/nginx/conf/ssl/host.domain.com
    /root/.acme.sh/acme.sh --installcert -d host.domain.com --certpath /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.cer --keypath /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.key --capath /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.cer --reloadCmd /usr/bin/ngxreload --fullchainpath /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-fullchain-acme.key
    then make a copy of /usr/local/nginx/conf/conf.d/virtual.conf as /usr/local/nginx/conf/conf.d/virtual.ssl.conf
    cp -a /usr/local/nginx/conf/conf.d/virtual.conf /usr/local/nginx/conf/conf.d/virtual.ssl.conf
    now edit within /usr/local/nginx/conf/conf.d/virtual.ssl.conf with ssl cert lines so looks like
      listen 443 ssl http2;
      server_name host.domain.com;
      ssl_certificate      /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.cer;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.key;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # dual cert supported ssl ciphers
      ssl_ciphers TLS13-AES-128-GCM-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-CCM-8-SHA256:TLS13-AES-128-CCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/host.domain.com/host.domain.com-acme.cer;
            root   html;
            access_log              /var/log/nginx/localhost.access.log     combined buffer=8k flush=1m;
            error_log               /var/log/nginx/localhost.error.log      error;
    # ssi  on;
            location /nginx_status {
            stub_status on;
            access_log   off;
            allow 127.0.0.1;
            #allow youripaddress;
            deny all;
    #Enables directory listings when index file not found
    #autoindex  on;
    include /usr/local/nginx/conf/include_opcache.conf;
    #include /usr/local/nginx/conf/phpstatus.conf;
    #include /usr/local/nginx/conf/vts_mainserver.conf;
    restart nginx
    ngxrestart
    now you should be able to access both https and non-https hostname and then if all is working do a non-https to https 302 temp redirect
    If you do have phpmyadmin.sh installed phpmyadmin, you can probably try this to fix the conflict via these steps.
    1. Get the contents of /usr/local/nginx/conf/phpmyadmin_https.conf and place it in your above created
    /usr/local/nginx/conf/conf.d/virtual.ssl.conf main hostname HTTPS nginx vhost within server{} context
    2. Backup locally copy of phpmyadmin.sh auto generated self-signed SSL cert HTTPS vhost at /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf
    3. Then take the below following values contained within /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf and transpose them into your above created
    keepalive_timeout 3000;
    client_body_buffer_size 256k;
    client_body_timeout 3000s;
    client_header_buffer_size 256k;
    ## how long a connection has to complete sending
    ## it's headers for request to be processed
    client_header_timeout 60s;
    client_max_body_size 512m;
    connection_pool_size 512;
    directio 512m;
    ignore_invalid_headers on;
    large_client_header_buffers 8 256k;
    4. Then remove /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf
    5. Test Nginx config & Restart Nginx & PHP-FPM
    nginx -t
    nprestart
  5. Cryptso
    Cryptso New Member
    9:01 AM
    45,406
    10,302
    5:01 PM
    Interesting been using Sublime for a few years I didn't know that LOL. Not that I use FTP at all, my SSH client has built in SFTP and just do it via command line i.e. put/get etc
