SSL Enabling HSTS for SSL ?
Discussion in 'Domains, DNS, Email & SSL Certificates' started by pamamolf, Nov 6, 2016.
    4,128
    2:07 AM
    I hate you lol :)
  2. pamamolf
    4,128
    2:07 AM
    Well i got the A+ :) lol
    Guess how.......
    On another topic that i create recent reporting that when i have an invision forum or a Wordpress site when i set them as offline/maintenance mode i am getting after a few refresh 502 errors ...... it seems it was related to that....
    After enabling the forum no more 502 errors and then without touching anything or even restart i did the check online and i have an A+ !!! :)
    But that confirms that there is an issue when they are set as maintenance mode :(
    60,082
    12,584
    9:07 AM
  4. pamamolf
    4,128
    2:07 AM
    I mean the setting at admin control panel that they have both Invision and Wordpress and not from Centminmod....
    Invision has offline mode and Wordpress has Maintenance mode....
    60,082
    12,584
    9:07 AM
    check what http status error message is reported when both web apps go into offline/maintenance mode
  6. pamamolf
    4,128
    2:07 AM
    On refresh one is ok and on second refresh 502 bad gateway and on third ok again and so on......
    It is going one by one....
  7. benyhirmansyah
    benyhirmansyah New Member
    7
    Indonesia
    6:07 AM
    1.11.x
    I never success enable HSTS on Wordpress following the tutorial here. But, for index.html, it works. Since Wordpress using index.php then it's not. Finally, I add these code in my custom functions.php and I see HSTS working.
    PHP:
    add_action( 'send_headers', 'strict_transport_security' );
     * Enables the HTTP Strict Transport Security (HSTS) header.
     * @since 1.0.0
    function strict_transport_security() {
    header( 'Strict-Transport-Security: max-age=31536000' );
    Why following centminmod.com/nginx_domain_dns_setup.html#hsts tutorial not working for index page based on .php?
  8. benyhirmansyah
    7
    Indonesia
    6:07 AM
    1.11.x
    I confirm that it works with other index.php files (my subdomain contain php script) besides wordpress. Still in Wordpress, I should add those custom codes above to make HSTS working.
    60,082
    12,584
    9:07 AM
    @benyhirmansyah strange it should work for HSTS on index.php
  10. benyhirmansyah
    7
    Indonesia
    6:07 AM
    1.11.x
    sure, here is mydomain.com.ssl.conf file:
    #x# HTTPS-DEFAULT
       server_name mydomain.com www.mydomain.com;
       return 301 https://$server_name$request_uri;
    # For SPDY SSL Setup
    #       listen   80;
    #       server_name mydomain.com www.mydomain.com;
    #       return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      include /usr/local/nginx/conf/ssl/mydomain.com/mydomain.com.crt.key.conf;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # mozilla recommended
      ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA256:EECDH+ECDSA+SHA384:EECDH+aRSA+SHA256:EECDH+aRSA+SHA384:EECDH+AES128:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!RC4:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
      add_header Strict-Transport-Security "max-age=31536000";
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      # ssi  on;
      access_log /home/nginx/domains/mydomain.com/log/access.log combined buffer=256k flush=60m;
      access_log /var/log/nginx/access.cache.log cache;
      error_log /home/nginx/domains/mydomain.com/log/error.log;
      include /usr/local/nginx/conf/autoprotect/mydomain.com/autoprotect-mydomain.com.conf;
      root /home/nginx/domains/mydomain.com/public;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
      #autoindex  on;
      #autoindex_localtime on;
      try_files $uri $uri/ /index.php?q=$request_uri;
      include /usr/local/nginx/conf/staticfiles-hsts.conf;
      include /usr/local/nginx/conf/mywpcache.conf;
      include /usr/local/nginx/conf/myphpcache.conf;
      #include /usr/local/nginx/conf/staticfiles.conf;
    60,082
    12,584
    9:07 AM
    strange that config should work for HSTS !
  12. benyhirmansyah
    7
    Indonesia
    6:07 AM
    1.11.x
    Yes, really weird. It doesn't work with Wordpress. Even, I run this command:
    curl -s -D- https://mydomain.com/ | grep Strict
    No results were returned.
    But, with other PHP script or index.html, it is working normally. As I said, when put my code above into custom functions.php in my Wordpress theme, then HSTS is working.
  13. noly
    noly Member
    106
    16
    Germany
    1:07 AM
    1.18.x
    10.2.x
    Not sure if it is the same issue like @benyhirmansyah had (or is having) with HSTS but i have a modx site - which from the .conf-point of view is very similiar to set up like wordpress - and getting 404s when navigating thru the site. I figured out that it's because of this location block in my staticfiles-hsts.conf:
    location ~* \.(html|htm|txt)$ {
        if ($server_https = 'on') {
            add_header Strict-Transport-Security "max-age=7776000;";
      #add_header Pragma public;
      add_header Cache-Control "public, must-revalidate, proxy-revalidate";
      access_log off;
      # expires 30m;
      expires 30d;
      break;
    When i comment that out then site works fine.
    index index.php;
    client_max_body_size 30M;
      # block exploits and sql injections
      #try to get file directly, try it as a directory or fall back to modx
      try_files $uri $uri/ @modx;
      location @modx {
        include /usr/local/nginx/conf/blockbots.conf;
        #including ? in second rewrite argument causes nginx to drop GET params, so append them again
        rewrite ^/(.*)$ /index.php?q=$1&$args;
      location /rest {
        try_files $uri $uri/ @modx_rest;
      location @modx_rest {
        rewrite ^/rest/(.*)$ /rest/index.php?_rest=$1&$args last;
      include /usr/local/nginx/conf/staticfiles-hsts.conf; #hsts for ssl labs test A+ : https://goo.gl/w2qEpt
      include /usr/local/nginx/conf/php-modx.conf;
      include /usr/local/nginx/conf/errorpage.conf;
        deny all;
    Researched centmin archives but couldn't find a hint.
    If it's important to know.. i am 301ing from http to https.
    Does somebody see my error here?
    60,082
    12,584
    9:07 AM
    could you elaborate on the issue with an example ?
