Nginx Enabling GeoIP 2 Lite Nginx Module questions ?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Itworx4me, Apr 9, 2019.
  1. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    47,292
    10,703
    2:58 PM
    haven't really tested it specifically - GeoIP/GeoIP2 is something you either need to use or you don't. But GeoIP legacy nginx module is installed by default in Centmin Mod so all the benchmarks done to date are with it enabled anyway. GeoIP 2 nginx module isn't installed by default though and only enabled via https://community.centminmod.com/threads/17165/
  3. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    I don't understand where to put this code:
    Then within your nginx vhost's server{} context add entry
    if ($country_code_allowed = deny) {
      return 444;
    Thanks,
    Itworx4me
  4. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    @eva2000 can you elaborate more on this?
    47,292
    10,703
    2:58 PM
    within nginx vhost's server{} context i.e. above the first location / webroot context.
  6. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    Can you give me an example.
    Itworx4me
    47,292
    10,703
    2:58 PM
      return 444;
  8. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    I am assuming that this is the correct file to edit?
     /usr/local/nginx/conf/conf.d/newdomain.com.conf
    I am curious as to why you wouldn't want to block it for all traffic into the server instead of per vhost site. Seems very tedious to change each vhost site hosted on the server.
    Thanks,
    Itworx4me
    47,292
    10,703
    2:58 PM
    You can put common nginx rules in your own include file i.e. /usr/local/nginx/conf/block_county.conf and reference that in your nginx vhost config files non-https at /usr/local/nginx/conf/conf.d/newdomain.com.conf or https vhost at /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf as
    include /usr/local/nginx/conf/block_county.conf;
    If you want server level blocking there's better tools such as CSF Firewall server level country blocking by editing /etc/csf/csf.conf CSF Firewall config file - something off topic for this thread. So for CSF Firewall questions ask at https://community.centminmod.com/forums/other-centmin-mod-installed-software.22/.
    47,292
    10,703
    2:58 PM
    to clarify both these methods do exactly same thing
    method 1 put directly in nginx vhost config files non-https at /usr/local/nginx/conf/conf.d/newdomain.com.conf or https vhost at /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf the following code above location / context
      return 444;
    or method 2 put the code in /usr/local/nginx/conf/block_county.conf
      return 444;
    and reference that as an include file in your nginx vhost config files non-https at /usr/local/nginx/conf/conf.d/newdomain.com.conf or https vhost at /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf above location / context
  11. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    I followed the your install Nginx - How to enable GeoIP 2 Lite Nginx Module Support ? I get nothing from running theses commands:
    lsof -p 2128 | grep .so | grep geo
    or
    lsof -p 2128 | grep GeoIP
    Nginx failed to start too:
    nginx -t
    nginx: [emerg] unknown "geoip2_data_country_code" variable
    Any ideas?
    47,292
    10,703
    2:58 PM
    Did recompiled nginx via centmin.sh after setting NGINX_GEOIPTWOLITE='y' and NGXDYNAMIC_GEOIPTWOLITE='y' set persistent config file at /etc/centminmod/custom_config.inc as instructed at Nginx - How to enable GeoIP 2 Lite Nginx Module Support ? ? If you did not, then you wont have GeoIP 2 support
    run command
    nginx -V
    to see if --add-dynamic-module=../ngx_http_geoip2_module is listed in output to indicate geoip2 nginx module is installed.
    also
    does your /usr/local/nginx/conf/geoip.conf look like below ?
    # SET the path to the .dat file used for determining the visitors country from the IP-address ###
    geoip_country /usr/share/GeoIP/GeoIP.dat;
    geoip_city /usr/share/GeoIP/GeoIPCity.dat;
    # GeoIP2 Lite databases
    #include /usr/local/nginx/conf/geoip2.conf;
    this line should have automatically be uncommented removed # hash if you recompiled nginx via centmin.sh with NGINX_GEOIPTWOLITE='y' and NGXDYNAMIC_GEOIPTWOLITE='y' set persistent config file at /etc/centminmod/custom_config.inc
    so should be
  13. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    This is what my /usr/local/nginx/conf/geoip.conf looks like. This isn't a fresh install.
    # cat /usr/local/nginx/conf/geoip.conf
    #  geoip2 /usr/share/GeoIP/GeoLite2-Country.mmdb {
    #    $geoip2_data_country_code country iso_code;
    #    $geoip2_data_country_name country names en;
    #  geoip2 /usr/share/GeoIP/GeoLite2-City.mmdb {
    #    $geoip2_data_city_name city names en;
    #    $geoip2_data_postal_code postal code;
    #    $geoip2_data_latitude location latitude;
    #    $geoip2_data_longitude location longitude;
    #    $geoip2_data_state_name subdivisions 0 names en;
    #    $geoip2_data_state_code subdivisions 0 iso_code;
  14. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    I added this line to the geoip.conf
    and nginx restarted this time.
    47,292
    10,703
    2:58 PM
    yes that is older config, you can replace contents of /usr/local/nginx/conf/geoip.conf with one at centminmod/centminmod - centmin mod won't auto change older installers version as you may have customised your geoip.conf so need to update it manually.
  16. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    Thank you for taking the time for this novice to learn how to install new stuff on there server.
    Itworx4me
  17. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    @eva2000 is there a way to deny all and only expect a few counties with geoIP2? If so, what does the code look like?
    Thanks,
    Itworx4me
    47,292
    10,703
    2:58 PM
  19. Itworx4me
    Itworx4me Member
    239
    23
    9:58 PM
    Nginx 1.17.X
    MariaDB 10.3.X
    I looked at post #9. I don't see where is says what I am asking for. I will give it a try here and if you could tell me if I am correct.
    map $geoip2_data_country_code $country_code_allowed {
      default deny;
      US allow;
      CA allow;
      AU allow;
      GB allow;
    Would this be the correct? Deny all but allow the US,CA,AU and GB to see the server?
    Thanks,
    Itworx4me
