Nginx Enabling GeoIP 2 Lite Nginx Module Errors
Discussion in 'Install & Upgrades or Pre-Install Questions' started by EckyBrazzz, Apr 17, 2019.
    60,640
    12,635
    6:16 PM
    yes answering yes will reset the php.conf contents :)
  2. alex_cmm
    alex_cmm New Member
    16
    7
    9:16 AM
    Great, I just did Update & overwrite your existing php.conf [y/n]: y , omg how dumb I can be. Have no idea what to do now, why did I touch anything. I am soo angry on myself now :mad:
  3. Itworx4me
    344
    35
    12:16 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    You will just have to go and re-apply the edits.
    60,640
    12,635
    6:16 PM
    if you check php_upgrade.log logs in /root/centminlogs you will see where php-fpm.conf and php.conf auto backed up before overwrite files are located so you can restore them :)
  5. alex_cmm
    alex_cmm New Member
    16
    7
    9:16 AM
    I see where they are:
    existing php.ini will be backed up at /usr/local/lib/php.ini-oldversion_050519-174300
    Want to update to latest php.conf & php-fpm.conf ? (overwrites will auto backup existing files)
    existing php.conf will be backed up to /usr/local/nginx/conf/php.conf-oldversion_050519-174300
    existing php-fpm.conf will be backed up to /usr/local/etc/php-fpm.conf-oldversion_050519-174300
    Have no idea what are my next steps. I am new to Linux and CentMin Mod, have no idea how to restore them. Dont want to make bigger mess then already is, damm I am angry :(
  6. EckyBrazzz
    190
    5:16 AM
    Well, as noop in Linux I used mc (midnight commander) and even in the good old time of MSdos a lot (yum install mc) and you can copy the oldversion to the new one. Just take care to copy it into the correct directory ;) with the correct old path/name.
    If you look at https://www.geeksforgeeks.org/cp-command-linux-examples/ you can use cp also
  7. alex_cmm
    alex_cmm New Member
    16
    7
    9:16 AM
    Ok this is how I did it:
    cd /usr/local/nginx/conf/
    cp -i php.conf-oldversion_050519-174300 php.conf
    Confirmed with y
    cd /usr/local/etc/
    cp -i php-fpm.conf-oldversion_050519-174300 php-fpm.conf
    Confirmed with y
    Not sure if I needed to restart nginx and php-fpm, probably yes so I did nprestart too.
    Did I do it right? Is this ok or I need to do something more?
  8. EckyBrazzz
    190
    5:16 AM
    Yes:
    restart Nginx + PHP-FPM services
         nprestart
    60,640
    12,635
    6:16 PM
    yeah restart nginx + php-fpm if unsure
    nprestart
    For command shortcuts see FAQ item 16. They're custom created files in /usr/bin i.e. /usr/bin/nprestart etc.
