Install Enable nginx brotli module if using cloudflare ?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Mrbo, Feb 26, 2019.
  1. Mrbo
    Mrbo Member
    11:46 AM
    Should I set these to no if I use cloudflare brotoli in front ?
    NGINX_LIBBROTLI='y'
    NGXDYNAMIC_BROTLI='y'
    PHP_BROTLI='y'
    If yes, do I need to recompile nginx after?
    54,647
    12,230
    2:46 PM
    With cloudflare, first 2 can be disabled but if you plan on using any php apps which do brotli compression i.e. wordpress autoptimize-gzip pre-compress gzip + pre-compress brotli, then should keep all 3 enabled and set to ='y'
    yes if you change first 2, recompile nginx via centmin.sh menu option 4
    3rd variable changes, recompile php via centmin.sh menu option 5
  3. Mrbo
    Mrbo Member
    11:46 AM
    Ok, so there are no problems if I use brotoli on cloudflare and also on the server with NGINX_LIBBROTLI='y' , NGXDYNAMIC_BROTLI='y' , PHP_BROTLI='y' enabled and also Autoptimize + your Autoptimize-gzip Wordpress plugin?
    54,647
    12,230
    2:46 PM
    no probs :)
