Stable Branch fix cmsec indeterminate verdict on Rocky security-repo .0.N kernels i…
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 22, 2026.
    60,144
    12,590
    5:37 AM
    fix cmsec indeterminate verdict on Rocky security-repo .0.N kernels in 132.00stable
    Rocky Linux's opt-in `security` repo ships downstream kernel re-spins with an
    extra .0.N suffix after the dist tag (e.g. 4.18.0-553.124.1.el8_10.0.2) — a
    parallel version lineage whose base can lag the RHEL baseline while still
    carrying backported fixes. dist_tag_compatible() refused the comparison so the
    checks returned indeterminate; merely loosening the regex would have reported
    false-vulnerable for CVEs whose baseline is numerically higher than the re-spin
    base (46300/46333).
    Changes:
    - Add running_kernel_changelog_confirms_fix() to all five checks; in the
    cross-lineage refuse-branch, consult the running kernel's own RPM changelog
    for the exact CVE marker (grep -iwF) and mark patched when present —
    authoritative regardless of version-string lineage. Set directly in the
    refuse-branch (not a late override, since upgrade_status makes vulnerable
    sticky), avoiding contradictory output.
    - 43500 queries kernel-modules-partner on the rxrpc-present path; the EL8
    not_affected short-circuit is untouched.
    - Emit changelog_confirms_fix in JSON output.
    - Enable the Rocky security-repo upgrade hint for the four kernel-core CVEs.
    132.00stable branch
